Petr Mikolasek Fidèle Posteur
Posté le: 15/06/2014 16:01 Sujet du message: |
Hello,
Kaczka is flying. This weekend I have to fly the Kaczka after reconstruction. The flying habits are excelent, but Kaczka is not standard glider. Piloting is differant but not difficult.
Video on: https://www.youtube.com/watch?v=RNnWoD07LAA
Posté le: 15/06/2014 16:41 Sujet du message: |
Glückwunsche Petr,
eine außergewöhnlich und sehr schönes Modell hast du da gebaut Ich wünsche Dir viel Freude damit
Gruß Johannes |
philippe44 Fidèle Posteur
Posté le: 15/06/2014 17:00 Sujet du message: |
wonderfull
where is the pilot ![[clap]](images/smiles/Clap.gif) |
Posté le: 15/06/2014 17:54 Sujet du message: |
Magnifique.
Michel |
Posté le: 15/06/2014 19:19 Sujet du message: |
Wonderful, Petr, stuning model ! ![[clap]](images/smiles/Clap.gif) |
Posté le: 15/06/2014 20:15 Sujet du message: |
Ahoj Petr,
Fantastic, congratulation
the stabilizer seem to be very sensitive
I can't wait to see it at the slope
nízký průlet z pravé strany
see you soon
Erix Fidèle Posteur
Posté le: 15/06/2014 21:45 Sujet du message: |
No krása. Taky se těším až to uvidím zblízka. Mooooc pěkná předloha když to pak letí.
Erix |
Posté le: 15/06/2014 21:48 Sujet du message: |
Hello Vincent,
the stabilizer is not sensitive.
Just my hands are shaking.
30% expo an it is OK. |
LV Maniaco Posteur
Posté le: 15/06/2014 21:56 Sujet du message: |
Petře gratuľujem Nech ti dlho robí radosť ![[amen]](images/smiles/amen.gif)
 Laco |
Posté le: 15/06/2014 22:00 Sujet du message: |
wonderfull
Posté le: 16/06/2014 09:27 Sujet du message: |
Very impressive. Congratulation!
I am also curious to see it flying on the slope.
See you at Retroplane.
Harold |
Posté le: 16/06/2014 17:53 Sujet du message: |
Posté le: 02/07/2014 01:12 Sujet du message: |
Ahoj Petr,
very impressive the video. Congratulations to this successful second first flight!
À bientôt dans les Vosges,
Frank
Posté le: 28/08/2014 22:21 Sujet du message: |
On Bolatice I have broke the fuselage of my Kaczka.
The reparation is almost finished.
Posté le: 18/09/2014 09:32 Sujet du message: |
Thanks Petr, beautiful video, but no egg at landing
Erix Fidèle Posteur
Posté le: 18/09/2014 10:33 Sujet du message: |
Ahoj Petře,
SUPER záběry. Podle Tvých informací s tím sice měli nějaké problémy ale originál létal velmi krásně klidně a svižně. Jdeš do té větší?
Erix |
Posté le: 21/06/2015 20:48 Sujet du message: |
Hello,
for better maneuverability i have built a new, larger rudders.
The flight characteristics are now excellent.
There is the video from last week.
https://www.youtube.com/watch?v=FK9wwnAO_LU
Rudders are larger by 20%
Posté le: 22/06/2015 06:47 Sujet du message: |
Congratulation Petr
see you soon at the Waku
Erix Fidèle Posteur
Posté le: 22/06/2015 17:11 Sujet du message: |
Ahoj Petře,
Tak koukám, že jsi se již s modelem sehrál. Přistání jsou jako do peřinky
Erix |
Posté le: 22/06/2015 18:08 Sujet du message: |
Posté le: 23/06/2015 00:25 Sujet du message: |
Ahoj Eriku,
loni jsem měl problémy se zatáčením a směrovou stabilitou. Zvláště se to projevovalo při přistáních, kdy model dost vybočoval a nešlo udržet přímý let. Při vyšších rychlostech se to neprojevovalo. Postavil jsem nové větší směrovky a na výškovku dal silnější rychlejší a přesnější servo. Nepatrně jsem ještě posunul těžiště dozadu a teď to je ono.
Teď strouhám pilota a dělám přístrojovku, abych to měl podle pravidel.  |
Posté le: 11/07/2015 23:33 Sujet du message: |
Cockpit and pilot for Kaczka
Posté le: 12/07/2015 02:24 Sujet du message: |
Whooo, as usually, very very beautiful work Petr I can't wait to see it at the Waku ![[bave]](images/smiles/bave.gif)
Erix Fidèle Posteur
Posté le: 12/07/2015 07:15 Sujet du message: |
Nedá se to nic jiného než pochválit Petře. Obecně musím přiznat, že je to mnohem realističtější s tím vybaveným kokpitem. Dává to tomu pěknou váhu.
Erix |
LV Maniaco Posteur
Posté le: 12/07/2015 15:34 Sujet du message: |
Cher Petr,
Excellente idée, le joystick!
Heureusement qu'il n'y a pas de contrôle à la pente.
Harold |
mAtzi Fidèle Posteur
Posté le: 22/08/2017 12:48 Sujet du message: IS-5 1:2,5 |
Ich hab die IS-5 im Maßstab 1:2,5 gebaut.
Ausgehend von den Unterlagen von Petr (auch hier nochmals: vielen DANKE!!)
hab ich alles entprechend vergrößert und mit den Flügelendscheiben und dem Höhenleitwerk zu bauen begonnen!
Zwischenzeitlich brachte Oldgliders/PL einen Frästeilsatz im selben Maßstab heraus, den ich für die Flügel und den Rumpf heranzog!
Wahrscheinlich eines der außergewöhnlichsten Modelle:
 ("da hauts di um"! )
Fliegt super und führt zu staunenden und anerkenneden Blicken am Flugplatz!
Bei der heurigen Segelflugmesse in Schwabmünchen 2017 durften wie sie im Slot mit Markus Frey und Patrick Trauffer vorfliegen:
Ein kitschiges Bild zum Abschluß
Posté le: 22/08/2017 12:55 Sujet du message: |
