Posté le: 04/10/2008 17:06 Sujet du message: Eagle Austria |
Walter or other... do you think it's possible to paint (or print on decal paper) this eagle picture on the rudder of my MG9a? in 1938 you think it could be? it comes from aeroclub.at I saw it was on the rudder of your MG19a.
I would like to have a little touch of color
do you have the logo in higher resolution than this one?
How do you make your eagle on the MG19? mine must have wings 55mm
Walter Incurable Posteur
Posté le: 04/10/2008 17:33 Sujet du message: |
Hi Vincent,
...I`m not sure if it is correct for 1938 - but the other question - no problem...
Please send me your adress per mp. I have two bigger ones with about 13cm. The smaller ones are about 70mm. I can send the two big decals on monday - the smaller ones are in about one week - I ordered them already.
amicalement
Walter |
Posté le: 04/10/2008 18:53 Sujet du message: |
Thank you very much Walter, but wait for the moment, I will tell you if you make them for me. 70mm will be good it's the maxi size I can put
your logo are print on clear or white paper?
clear will be better for the letters at the bottom, but the white on the flag must be paint
I'm looking to buy decalpaper or other sticker clear paper
do you have the logo in hight resolution?
Posté le: 04/10/2008 20:40 Sujet du message: |
Salut Monsieur le Chef... ,
...I have the original decals from the Aeroclub - not made by a graphic shop. I don´t have the logo as a digital datasheet on my PC.
So with these stickers you can make what you want. You can put it directly on your rudder (it´s very thin and already cutted) - or you can scan it to your PC to plot it. It´s no problem - you will have them as soon
as I get them...
Walter |
Posté le: 16/10/2008 16:24 Sujet du message: |
Walter, thank you very much for the stickers
Stephan Psycho Posteur
Posté le: 18/10/2008 09:42 Sujet du message: |
Walter tu fais beaucoup de progrès en Français
je vous souhaite bons vols ce week-end, j'espère que tu feras voler le kirby Kite, et Steph des photos
