tayyar Stagiaire Posteur
Posté le: 30/01/2014 19:20 Sujet du message: Planeur Ecole S20 |
Good evenning, everybody..
I just have been started with a project, Sablier "Planeur Ecole S20".
I know this glider since my childhood; I had a book [Guide for Glider and Motor-glider Construction] translated and published in 1938. I had gifted it to a younger modeller, several years before.
Last two days, I built a small model of it (22 cm overall length and ca. 30 cm wing span) as an initial work. It glides as good as it can, using 5 pins as ballast weight at the front edge of the skid, and now is sitting on the top of my PC's monitor.
It is now, the turn of the 1/10 scale model (and perhaps, 1/5 R/C later)..
PROBLEM:
Last night I tried to post this, but had no success. I could not see my new theme, after clicking "envoyer" button. I cannot post pictures, either. This is, perhaps, becouse I am a big "null" at French Language
Someone, please, HELP!
 Unter den Wolken :) |
Posté le: 30/01/2014 19:27 Sujet du message: |
Iyi akşamlar
welcome to the forum
for the photos, you must resize them before at the right size 600 pixels maxi and Under 100 ko
look at here http://www.retroplane.net/forum/viewtopic.php?t=3808
Posté le: 30/01/2014 19:32 Sujet du message: |
Bon Soir,
Thank you for helping hand
I am gonna try tomorrow, becouse my camera is not here tonight.
