Planeur Ecole S20
tayyar
Âge: 63 Scorpion
MessagePosté le: 30/01/2014 19:20    Sujet du message: Planeur Ecole S20 Répondre en citant
Good evenning, everybody..
I just have been started with a project, Sablier "Planeur Ecole S20".
I know this glider since my childhood; I had a book [Guide for Glider and Motor-glider Construction] translated and published in 1938. I had gifted it to a younger modeller, several years before.
Last two days, I built a small model of it (22 cm overall length and ca. 30 cm wing span) as an initial work. It glides as good as it can, using 5 pins as ballast weight at the front edge of the skid, and now is sitting on the top of my PC's monitor.
It is now, the turn of the 1/10 scale model (and perhaps, 1/5 R/C later)..
PROBLEM:
Last night I tried to post this, but had no success. I could not see my new theme, after clicking "envoyer" button. I cannot post pictures, either. [argh] This is, perhaps, becouse I am a big "null" at French Language Sad
Someone, please, HELP!
Unter den Wolken :)
MessagePosté le: 30/01/2014 19:27    Sujet du message: Répondre en citant
Iyi akşamlar
welcome to the forum Very Happy
for the photos, you must resize them before at the right size 600 pixels maxi and Under 100 ko
look at here http://www.retroplane.net/forum/viewtopic.php?t=3808
tayyar
Âge: 63 Scorpion
MessagePosté le: 30/01/2014 19:32    Sujet du message: Répondre en citant
Bon Soir,
Thank you for helping hand Very Happy
I am gonna try tomorrow, becouse my camera is not here tonight.
Unter den Wolken :)
Poster un nouveau sujet   Répondre au sujet    RETROPLANE.net Index du Forum -> Mini Maquettes Toutes les heures sont au format GMT + 1 Heure
