| Auteur | Message |
| ultralajt Fidèle Posteur
|  Posté le: 18/04/2014 12:53    Sujet du message: Wing spar dimensioning |     |
| Hi!
 What max G load and safety factor is reasonable to use at designing vintage scale sailplane model in scale range from about 1:3 to 1:2,5?
 I am curently designing a model in 1:2,5 scale that is kind of Grunau Baby variant.
 I am thinking that scale sailplane is to fly with care and thats why I chose ultimate load factor of (only) 10.  Is this okay or not?
 The wing spar caps are made from spruce and I use material strength:
 34 N/mm2 for compression
 and
 64 N/mm2 for tension
 What ultimate G load and material data you use for your spar caps sizing?
 Mitja
  Never try, never fail....
| Christian_B Fidèle Posteur
|  Posté le: 19/04/2014 19:04    Sujet du message: |     |
| I think that your load factor of 10 is perfect for such gliders with spruce spars. I have an simple excel sheet on my homepage where you can find all the material data I'm using (look under download).
|  Posté le: 19/04/2014 19:32    Sujet du message: |     |
| Thank you!
 | Vous ne pouvez pas poster de nouveaux sujets dans ce forum Vous ne pouvez pas répondre aux sujets dans ce forum
