bocorvin Maniaco Posteur
Posté le: 19/07/2025 12:19 Sujet du message: Kupper Ku4 Austria "Elefant" scale 1:6 |
Building Kupper Ku 4 (Elefant) scale 1:6, built from the FMT plans
Fotor had previously owned an Elefant, see this link
www.retroplane.net/forum/viewtopic.php?p=68869
but is broke its wing when towed and he decided to build another one, it is surely a remarkable glider!
Fotor writes;
This thread (building thread on the Dutch MBF) started at the end of 2013. 11.5 years ago. The last construction activities were 2.5 years ago, and the construction breaks have become longer and longer.
After those last construction activities, I had to slow down in many areas. My desire to build has also diminished. Well... Will that Elefant ever be completed? It would be a shame if it weren't, because it's such a unique machine.
I started thinking about whether I wanted to finish this project. I still want to, but at the same time, I seem to have lacked the right motivation for a long time. That's why I decided to look for someone who would be willing to take over the project.
The first name that came to mind was Vincent de Bode, a good friend, fellow club member and fellow townsman, and a gifted model builder. He had to sleep a night over it to decide, but he's going to take over the project. I'm happy about that! Vincent has already built many “special” scale models and is a fan of unique gliders. What's more, he's a very talented builder.
Vincent's idea was to have a kind of co-ownership after the build so that I can still fly the Elefant from time to time. I think that's great! I will probably also be the one to fly it in.
Vincent came by today and I handed over all the materials. With a little pain in my heart, but with more joy that the chance of the Elefant flying has become a lot bigger.
Vincent (DB) writes further
First a few remarks about the Ku 4 an extreme glider from the 30’s, with a wingspan of 30! Meters.
Thomas posted an article about it on 12/01/2025 17:59 on this forum
Now my adventures finishing this glider;
Just under a week ago, I found myself with a three-quarters completed Elefant (Ku4) in my attic. It took a moment to process, something like, what, where, how? But apparently I like that. I found the necessary information on Retroplane, Thomas had posted a beautiful set of photos on Retroplane, I'll include a few.
This (extreme) aircraft hasn't flown much, with a wingspan of 30 metres and weighing just under 500 kg, it's not exactly a handy structure, but that's less of an issue for the model. The Ku 4 or Elefant (it was heavy, big, grey and had two fins) broke up while flying in the clouds (with minimal instruments and virtually no flaps), but the pilot landed safely with a parachute. The plane was completely destroyed, in short, it surely was a daring project.
Then I sat down quietly in front of Raymond's construction, which was very neatly built and surely complicated! The tip ribs are really tiny, compliments to Raymond.
Where to start?
After studying the photos and the FMT drawing (which Raymond included), I first filed the nose cone into shape.
Then the front of the neck; the photos were different from the FMT drawing, so I made it a bit straighter. Inside the fuselage, I made some shelves with space for ballast, the receiver battery and the uncoupler servo.
I also made the core of the skate simple, using 8 mm balsa wood without suspension.
I put in the pilot, he realy had to sit that low.
To be continued
Vincent (DB)
Posté le: 01/08/2025 15:21 Sujet du message: |
I continued with the nose of the fuselage, glued 0.6 mm plywood on both sides of the skate and the lower planks of the fuselage.
Once the fuselage has been glassed (with 25 gram cloth) the skate itself will be attached.
The horizonral stabiloizer mounting plate with wooden spacers so that the tail will not crackwhen tightening the bolts.
Gradually, I got more familiar with the construction. I noticed that in the design (drawing of the FMT), the fairly thin tail boom was made of balsa wood. A strong nose, large wing and a stabiliser with two fins all connected with a balsa tube, combined with my landings, I was afraid that it would break quite easily. I therefore decided to make four “girders” from glass roving.
Using a specially made sanding block, I sanded four 5 x 1 mm grooves, which was good exercise for my muscles...
Pre-impregnated glass roving (four per groove) were anchored to sturdy points in the fuselage nose
This gave me a bit more peace of mind.
Then the cockpit. The pilot (Kronfeld I presume) could enter through a hatch, when closed only the upper half of his head protruded above the fuselage. The instrument panel is very close!
More nice photos from Thomas article of the Ku4
After the necessary gluing and sanding, this is what it looks like.
I'm leaving the top of the fuselage open for now, so I can still reach it, first to finish the wings with servos.
Vincent(DB). |
Posté le: 11/08/2025 14:01 Sujet du message: |
Now that the fuselage was coming along nicely, I decided to start working on the wings.
First of all, I would like to compliment Raymond on how he built the wings and took care of the wiring.
To illustrate this, here is a photo of a some ribs. Just looking at them makes them break... (apparently there was something wrong with these ribs, they were over).
In order to position the hinges properly and easily so they can be glued in later, I made a kind of box out of 0.6 plywood strips with 2X2 slats.
The slats were planed down to the thickness of the hinges
Using a saw blade and sandpaper, I made slotted holes in the front of the aileron.
The plywood glues nicely to the balsa upper sheeting.
I had to chamfer the opening of the boxes so that the hinge would fit nicely. Fortunately, that worked well, and the aileron fitted nicely, just a very small gap.
Then I tested the wiring and cut the already built in spoilers free. They worked perfectly!
The cable bundles for the wings were not complex, and a 3 mm carbon rod with a tie wrap ensured that the connectorss did not fall into the bottom of the fuselage neck.
Now I could glue the fuselage shut with confidence.
Vincent (DB) |
Posté le: 12/08/2025 16:52 Sujet du message: |
Hello Vincent !
"aux petits oignons" cette reprise de construction
Ce planeur, de forme si particulière… ça devrait être sympa à cette "petite" échelle ; au plaisir de la suite
Posté le: 12/08/2025 20:20 Sujet du message: |
Hello Sebastian,
Merci pour ton interet.
Oui cette une planeur exceptionelle, 30 metres envergure!!
Cette modele est construit par les plan de FMT
L''histoire complet est aux MBF Neerlandaise:
https://www.modelbouwforum.nl/threads/austria-elefant-ii.200373/
Amicalement,
Vincent (DB) |
Posté le: 25/08/2025 12:51 Sujet du message: |
I continued to sheet all the surfaces. I thought if I coated it with glass cloth and epoxy the surface becomes much firmer and it also adds strength. I wanted to keep it light. I ordered 25grams glass cloth and started. First I covered the tail boom with 80 grams of fabric to make the tailboom a bit stronger.
The 25gram cloth turned out to be woven differently than the heavier cloths and it was not easy to laminate it neatly. I hoped that spray putty would make the visible tissue structure disappear, but unfortunately that turned out differently. I then had to fill and sand everything smooth, that was a good arm exercise.... Anyway, the surfaces feel smooth and I hope it will look good after spraying.
In any case, the balsa ailerons have become much more torsionally stiff.
Now I can start on the construction of the fin and rudder.
Vincent (DB) |
caralp_laurent Psycho Posteur
Posté le: 01/09/2025 09:20 Sujet du message: |
Hi Vincent,
Nice job !
And happy birthday !
Friendly,
Sénèque |
Posté le: 05/09/2025 11:09 Sujet du message: |
Wih the fins and rudders I had to make a choice. In the FMT drawings, the fins and rudders are flat plates constructed from balsa wood. On the 1:2 model and the original, they are fabric-covered structures
I decided, also in the hope of keeping it lighter, to build them from ribs. That was a challenge for me to draw in Devwing, but I managed it in the end,
Adri milled the ribs and TE in balsa and plywood
I planned to make the front spar from 3mm aluminium tubing, which is easy to bend, but the curved spruce spars were more difficult. I was able to bend them into the right curve using boiling water
and let them dry. To create a hinge, I used 1.5mm epoxy strips with 1.0 mm holes through which a 0.8 mm steel wire through it, so that the rudder remains removable.
The fin is attached to the stabiliser with two nylon M3 bolts, (on the photo they are from steel) removable for transport and so on.
The second rudder went a bit faster.
Both rudders in place,
Raymond built servos into the stabiliser, the control rods come under the stabiliser.
Unfortunately the fin and rudder are not much lighter than the ‘FMT’ rudders, but hopefully it looks better once they are sheeted with diacov and painted.
Vincent (DB) |
Posté le: 04/10/2025 19:01 Sujet du message: |
After sheeting the rudders with Diacov, I wanted to organise the nose of the fuselage with the battery and ballast. The battery didn't quite fit behind the nose block, so I placed it one frame backwards. Next to the battery, I added a switched power supply. I also made a charging and balancing cable so that the lifepo battery can remain in the fuselage.
The battery is held in place with a plywood board on which the servo for the coupling is mounted.
I can unscrew the 1.2 mm steel coupling wire from the servo lever, which is handy for inserting the ballast.
Moving on to the wings, I glued all the hinges in place with PVA. I made the coupling rods between the servo and rudders from pieces of M2 threaded rod with quick links on both sides.
There was not enough space for this with the ailerons. I put a stainless steel M2 threaded rod in a drill and used my power file to smooth the threaded rod and taper it to 1.5 mm.
I then bent it into a Z curve and it just fitted.
Now I could connect all the moving surfaces. I adjusted them mechanically to zero and then I adjusted the throws in my transmitter.
I set the throw of the ‘inner’ ailerons to 25% in the mixer, which gave about half the throw of the "outer"aileron. The idea is that they work together, to get a decent rol rate.
For the first time, I put it all together, impressive wingspan in the attic!
I put two temporaraly screws in the fuselage where the centre of gravity (10 cm from the leading edge) should be according to the FMT drawing.
This gives me an idea of how much lead is needed. In the photo, there is 1080 grams in.
Because that is a lot of lead, I checked the cg with ecalc, which gives 10.16 to 11.26 cm from the leading edge. The centre of the wing connector tube is at 10.70, which is exactly in the middle of the range. Raymond did a perfect job.
Hopefully the weather will calm down a bit so I can sand and spray outside, which is always exciting.
Vincent (DB) |
Posté le: 04/10/2025 19:22 Sujet du message: |
Hello Vincent,
SUPER !!! tu approches bientôt la fin des gros travaux !!!
Toujours impressionnant l'énorme allongement des ailes
Tu arrives à quelle poids au total actuellement ?
Au plaisir de la suite qui ne va pas tarder.
PS : quel enduit tu utilises pour boucher les irrégularités de la structure ?
J'ai un vieux pot d'enduit AXTON light… que je devrais pouvoir ré-activer avec de la colle blanche diluée pour que ça redevienne une "crème" facile à étaler…
Posté le: 04/10/2025 21:37 Sujet du message: |
Hello Sebastian,
Thanks for your nice comments .
The balsa is covered with 25gr/m2 glas fabric & epoxy. Rhat gave a irrigular surface . I used a filler (enduit) acrylic Rapide from Jansen, which worked very nicely.
The weight is approx 5.4 kgs, maybe its going to be a bit less with the other CG, but not much...
Amicalement,
Vincent (DB) |
Posté le: 13/10/2025 14:38 Sujet du message: |
I looked for the necessary lead I needed 850 gr, 90 grams of which I put separately in a plastic jar, so that I could take it out if necessary. I fixed the rest with epoxy with filler.
Now the finishing. After all that preparation, it had to be sprayed, but what colour? The photos are only black and white. On one of the better drawings the colour is named as "Dural Grey from Junkers" and on another photo the KU-4 has a white nose tip, which gave me the idea that it was quite a bit darker grey.
It also had the nickname "Elefant" and elephants are also quite grey. It remains a gamble and I chose a metallic grey.
Fortunately, the wind died down and I was able to spray outside.
at first I left the rudders Diacov white, but when I had to buy another rattle can (the third one), I sprayed them too.
I took the Ku-4 to our field to show it and take a few pictures.
It is a large and very special model!
I'm very curious how it looks flying.
The plan is that Raymond will fly the maiden, which I like. After all, I have only done a part of the construction and Raymond is a much more experienced pilot.
Vincent (DB) |
Posté le: 13/10/2025 21:05 Sujet du message: |
Hi Vincent,
850 gr de plomb c'est beaucoup… mais logique vu la forme de ce planeur.
Bonne chance pour le premier vol qui ne devrait pas tarder !
Et si tu peux faire une vidéo comme tu as l'habitude de le faire, ce serait top
to follow it
Posté le: 14/10/2025 10:10 Sujet du message: |
Hi Sebastian,
Yes, it is quite a lot of lead, almost all my lead supply went into the Ku-4!!
Because the rudders are hard to actuate with rods or wires without to much hysteresis, Raymond put 3 servo's in the horizontal stabilizer. Two for the rudders and one for the elevator. That is a very wise solution, but it adds some weight in the tail. I also reinforced the tailboom with some glass/epoxy, I was afraid that the boom wasn't able to withstand my landings.... That adds also some weight.
Surely I'll try to make soem video's and I am looking forward how the Ku-4 will look in flight!
Vincent (DB) |
Posté le: 14/10/2025 11:36 Sujet du message: |
Ok, je vois bien l'histoire du plomb nécessaire.
C'est pour ça qu'il faut surveiller au mieux l'équilibre statique tout au long de la construction pour avoir le moins de plomb à mettre au final.
Il vaut mieux renforcer généreusement les structures en bois que de mettre du "poids mort" avec du plomb ensuite dans le pif
Au plaisir de ta prochaine vidéo de first flight ! tout va bien se passer comme d'habitude
ThomasF Psycho Posteur
Posté le: 14/10/2025 19:07 Sujet du message: |
Danke Thomas
LG
Vincent (DB) |
Posté le: 15/10/2025 06:54 Sujet du message: |
Nice job Vince, we are expecded the maiden flight with impatiance
Posté le: 20/10/2025 10:49 Sujet du message: |
Hello everyone,
Yesterday the Austria made its maiden, flown by Raymond, who did the first 70% of the build. He wrote the following on the Dutch forum:
Translated with help of Deeptranslate L
Today the new Elefant made its first flights at the tow meeting in Kampen. The wind was somewhat challenging but it turned out to be doable. Towing was stable, no problem.
Flying is always a bit 'approximately' with these types of models. You steer and sometimes the model does exactly what you ask, more often it does something close. The Elefant is rather clumsy on rolling due to its relatively large wingspan, but on pitch it is very direct due to the short-tailboom. That imbalance takes some getting used to. Furthermore, the Elefant hooks firmly when rolling, so the rudders must be actively steered for nice turns. The glide angle is not so bad. Oh well, you don't fly an old-timer scale glider for the fantastic flying characteristics, you fly it for the nice view. And that is beautiful and above all special. We call the difficult steering 'character'.
Video made by Raymond, pictures by Rob t.
https://youtu.be/Zj0f4abwMLA
The Elefant will be hanging in my hangar again. Vincent has indicated that he finds flying with the Elefant quite exciting and fears that the Elefant would not have much time to fly with him. Today Vincent steered with the Elefant, which confirmed his suspicion. He does not get along very well with the special flying characteristics of this model. So the Elefant will come to me again soon. I owe Vincent eternal gratitude for finishing this model nicely. I don't know if it would have come to that for me. Construction started more than 10 years ago and in recent years things have been going well. A thousand thanks Vincent!
Rob took some shots;
I wrote this on the forum:
You have expressed that well Raymond and your thanks are very much appreciated! It is nice that this special aircraft is back in the familiar and good (flying) hands.
Finishing the build was a process from which I learned a lot. I prefer to fly with a somewhat easier to handle aircraft! Lots of good flights Raymond!!
Vincent(DB) |
Posté le: 20/10/2025 13:28 Sujet du message: |
The smile on your face, like all we have when the first flight it's going on perfect
And it's always impressive to see how the wings curve... even though they're made entirely of wood
Bravo for this first flight "nickel chrome aux petits oignons"
Posté le: 20/10/2025 15:27 Sujet du message: |
Hi Sebastian,
You saw that well, yes I was very happy; it flew well, everything functioned, the CG was OK and the footage was OK!
And there is room in my workshop
Vincent (DB) |
Posté le: 20/10/2025 16:39 Sujet du message: |
Glückwunsch zu deinem neuen Flugzeug
Ein sehr schönes Flugbild und dazu
passender super Pilot und Erbauer
Liebe Grüße
Posté le: 20/10/2025 18:11 Sujet du message: |
Danke Johannes
Der tekst war auf English, Ich war nicht der Flieger, nur ein kurze Zeit. Um klar zu sein habe Ich das ubersetzt mit hilfe von translate;
Gestern machte die Austria ihren maiden, geflogen von Raymond, der die ersten 70 % des Baus gemacht hatte.
Auf niederländischen Forum (MBF) schrieb er Folgendes: „
Heute absolvierte der neue Elefant seine ersten Flüge beim Schlepptreffen in Kampen. Der Wind war etwas herausfordernd, aber es erwies sich als machbar. Der Schlepp war gut, kein Problem. Das Fliegen ist bei solchen Modellen immer etwas „ungefähr“. Man lenkt, und manchmal macht das Modell genau das, was man will, häufiger aber fast. Der Elefant rollt aufgrund seiner relativ großen Spannweite eher schwerfällig, aber beim Hoch/Tief ist er aufgrund des kurzen Heckauslegers sehr direkt. An dieses Ungleichgewicht muss man sich erst gewöhnen. Außerdem hakt der Elefant beim Rollen stark, sodass die Ruder für schöne Kurven aktiv gelenkt werden müssen. Der Gleitwinkel ist gar nicht so schlecht. Na ja, man fliegt einen Oldtimer-Scale-Segelflugzeug nicht wegen der fantastischen Flugeigenschaften, sondern wegen der schönen Aussicht. Und die ist schön und vor allem besonders. Wir nennen die schwierige Steuerung „Charakter“.
Der Elefant wird wieder in meinem Hangar hängen. Vincent hat angedeutet, dass er das Fliegen mit dem Elefanten ziemlich spannend findet und befürchtet, dass der Elefant nicht viel Zeit zum Fliegen mit ihm haben wird. Heute hat Vincent mit dem Elefanten gesteuert, was seine Vermutung bestätigt hat. Er kommt mit den besonderen Flugeigenschaften dieses Modells nicht so gut zurecht. Der Elefant wird also bald wieder zu mir kommen. Ich bin Vincent unendlich dankbar für die wunderschöne Fertigstellung dieses Modells. Ich weiß nicht, ob ich es so weit gebracht hätte. Der Bau begann vor über 10 Jahren, und in den letzten Jahren ist er wirklich ins Stocken geraten. Tausend Dank, Vincent!
Du hast es gut ausgedrückt, Raymond, und dein Dank ist sehr willkommen!
Es ist wunderbar, dass dieses einzigartige Flugzeug wieder in vertrauenswürdigen und fähigen (fliegenden) Händen ist. Die Fertigstellung war ein weiterer Prozess, bei dem ich viel gelernt habe.
Ich würde viel lieber ein einfacher zu fliegendes Flugzeug fliegen! Viele schöne Flüge, Raymond!
LG Vincent (DB) |
Posté le: 20/10/2025 19:15 Sujet du message: |
Hallo Vincent,
danke für die Erleuterung.
Dennoch hast du dieses Flugzeug sehr gut fertiggestellt
Freue mich schon auf weitere Bauberichte.
LG J
Posté le: 23/10/2025 08:09 Sujet du message: |
Superb Vincent, congratulations
Friendly,
Sénèque |
