Mead Challenger
andrei_i
MessagePosté le: 26/10/2012 17:11    Sujet du message: Mead Challenger Répondre en citant
Hi everyone,
Can anyone help me with details about the Mead Challenger glider?
The glider has kingpost (i think this is the term) in some pictures and in other pictures don't. What exactly is the difference between this gliders? If you have some specs and blueprints it would be perfect.
Thank you very much.
MessagePosté le: 26/10/2012 18:05    Sujet du message: Répondre en citant
Hello Andrei, welcome to the forum Very Happy
I don't know this glider, original look, did you have other pics? where the picture came from?
You want to build the model?
andrei_i
MessagePosté le: 26/10/2012 19:05    Sujet du message: Répondre en citant
In the photo above is Mead Challenger glider that was built in 1931 by Jean Barboi in Romania with blueprints brought from USA. This is pretty much all i know about this glider.
Another photo with Mead Challenger built in Romania:
Mead Challenger with kingpost:
ultralajt
Nouveau messagePosté le: 08/11/2012 13:29    Sujet du message: Répondre en citant
Obviously gliders with kingpost are equipped with so called "Flying wires"(lower fuselage to wing) and "Landing wires" (kingpost to wing).
"Kingpostless" version is equipped with solid wing struts.
Version with kingpost usually weight less, but have larger air drag and time consuming rigging-assembly, while version with struts has larger weight, but less air drag and simplier assembly at field.
Mitja
Never try, never fail....
