What is this
Vit
MessagePosté le: 05/11/2012 18:01    Sujet du message: What is this Répondre en citant
There is the photo of very interesting thing that pilots had in cabin.
Do you know what is this?
Vít
MessagePosté le: 05/11/2012 18:56    Sujet du message: Répondre en citant
[humm] [humm] [humm]
The pilot put a pea in each box like a checklist Laughing
MessagePosté le: 05/11/2012 20:29    Sujet du message: Répondre en citant
C'est un calendrier de l'avent!
It's a kind of an Advent calendar!
Laughing
Vit
MessagePosté le: 05/11/2012 21:20    Sujet du message: Répondre en citant
[non] [non] [non] [non] [non] [nananere] [nananere] [nananere] [nananere] [nananere]
Petr Mikolasek
Âge: 50 Sagittaire
MessagePosté le: 05/11/2012 22:20    Sujet du message: Répondre en citant
To vím opět naprosto přesně. [humm] Je to manuál pro začínající letce za polárním kruhem Laughing
It is manual for beginners pilots in Arctic areas.
MessagePosté le: 06/11/2012 06:08    Sujet du message: Répondre en citant
That's a rosary for the co-pilot, he prays when he fly MDR
more seriously, strange object [humm] you must put something in the box? finger? it's for security?
Âge: 79 Verseau
MessagePosté le: 06/11/2012 09:06    Sujet du message: Répondre en citant
Some kind of dictionary / language help?
Used when you are landing in the field.
Or a a checklist, as already explained by Vincent?
Is it fixed in a sailplane? You found it in a museum?
Harold
Thierry Cavalié
Nouveau messagePosté le: 11/11/2012 03:49    Sujet du message: Répondre en citant
I don't know what it is exactly but I think to a kind of talisman dedicated to a pilot of a german world war two bomber like a Ju 88 because the "Rechts" (Right) cell just before the "Motor" (Engine) one.
In fact, this thing sums up well enough the motives to crash with such aircraft...
Je ne sais pas exactement ce que c'est mais je pense à une sorte de talisman dédié à un pilote de bombardier allemand de la 2ème guerre mondiale comme un Ju 88 à cause de la case "Rechts" (Droite) juste avant la case "Motor" (Moteur).
Cet objet résume assez bien en effet les motifs pour se casser la gueule avec un tel engin...
Cordialement,
Thierry
Vit
Nouveau messagePosté le: 11/11/2012 10:20    Sujet du message: Répondre en citant
Hello
I am sending solution of my guess.
On-board accident log for reporting the cause of an accident,late
1920s-early 1930s
Atypical part of aircraft equipment, called Unfallmelder, a sort of counterpart of today´s "black box", was produced and used in Germany. In the event of an accident, the aviator was expected to report its cause. The investigation commitee could later use this "testimony from the grave".
Vít
Nouveau messagePosté le: 11/11/2012 10:30    Sujet du message: Répondre en citant
Ahoj Vít,
It was a very interesting riddle [clap]
but how he marked the box? with a token in the cell? or the background is in paper and he made a hole with finger?
