Adler Fidèle Posteur
 Posté le: 12/11/2012 11:17    Sujet du message: DFS Olympia |
Hello,
I started building scale glider DFS Olympia Meise. Wingspan 4300 mm.
Construction of the model has its own. The photo unfinished hull glider.
Peter
 Posté le: 12/11/2012 12:23    Sujet du message:  |
Congratulation Peter
The winter arrive with lot of building to follow ![[houla]](images/smiles/houla.gif)
 Posté le: 12/11/2012 12:44    Sujet du message:  |
Ein schönes Vorbild hast du dir da ausgesucht
Und endlich  ist hier wieder was mehr los
Gruß Johannes |
 Posté le: 12/11/2012 14:36    Sujet du message:  |
Vielen Dank. Olympia ist eine schöne glider   |
 Posté le: 12/11/2012 15:08    Sujet du message:  |
This is beautiful. Thank you for the link. Super. ![[clap]](images/smiles/Clap.gif)  |
 Posté le: 12/11/2012 15:13    Sujet du message:  |
I'll do this coloring. But I do not know?
 Posté le: 12/11/2012 15:58    Sujet du message:  |
Yes I understand. Probably do our Czechoslovak marking. Home airport Kralupy 1947th
 Posté le: 12/11/2012 17:37    Sujet du message:  |
Christian |
michel Serial Posteur
 Posté le: 12/11/2012 18:34    Sujet du message:  |
     quel succès ce N.2000   |
 Posté le: 13/11/2012 09:47    Sujet du message:  |
Again an interesting project. A beautiful model, which fly very well.
And also a very clean workshop.
Harold |
 Posté le: 09/01/2013 11:05    Sujet du message:  |
Hi,
I continue to build mock Olympia. My work is a little slow. The spring must fly.
Petr   |
 Posté le: 09/01/2013 11:10    Sujet du message:  |
  I find it's quick built, most of the work is done
 Posté le: 09/01/2013 11:18    Sujet du message:  |
It does not seem so, but it is still a lot of work.   |
 Posté le: 10/01/2013 09:55    Sujet du message:  |
Beautiful. Congratulations.
Harold |
 Posté le: 28/05/2013 15:46    Sujet du message:  |
Hello,
So Olympia is almost complete. There is still the canopy. And then you want good weather for the first flights.
Petr
 Posté le: 28/05/2013 16:48    Sujet du message:  |
 Posté le: 28/05/2013 19:11    Sujet du message:  |
Glückwunsch, Petr
Es ist wunderschönes Modell geworden
Johannes |
 Posté le: 28/05/2013 19:55    Sujet du message:  |
Hi,
thank you      |
RichardP Accro Posteur
 Posté le: 28/05/2013 22:10    Sujet du message:  |
báječný
(I hope it's right) |
Walter L. Maniaco Posteur
 Posté le: 28/05/2013 22:11    Sujet du message:  |
Hello Petr,
congratulations for this fantastic model
What profil did you use? It looks like the original Gö.... (549?)
and what is the weight of the completed model?
Kind regards
Walter |
LV Maniaco Posteur
Erix Fidèle Posteur
 Posté le: 29/05/2013 06:00    Sujet du message:  |
Ahoj Petře,
No letadel máš víc než dost a krásné. Takže Vlašim už vyjde nebo si to všechno schováváš až na Rokycany?
Erix |
 Posté le: 29/05/2013 07:29    Sujet du message:  |
Ahoj Eriku,
jasně,do Vlašimi pojedu. Škoda že Vám nevyšlo to počasí,letos to je zatím nějaké na draka.
Uvidíme se.
Petr |
 Posté le: 29/05/2013 07:34    Sujet du message:  |
	« Walter L. » a écrit: 	Hello Petr,
Kind regards
Hello Walter,
airfoil is mine. I had it done.
Weight is about 8 - 8.5 kg. |
 Posté le: 29/05/2013 08:30    Sujet du message:  |
Nice model, mine is almost completed too..      |
Petr Mikolasek Fidèle Posteur
 Posté le: 30/05/2013 07:00    Sujet du message:  |
Ahoj Petře,
krásný model. Bude to zdatný konkurent pro polského Orlika III. Doufám že se po 75 letech budou opět spolu prohánět po obloze. Kdo zvítězí tentokrát?  ![[humm]](images/smiles/humm.gif)  |
AlainB Fidèle Posteur
 Posté le: 30/05/2013 13:59    Sujet du message:  |
Bravo
Très belle déco , une de mes préférées  .... Je m 'en étais largement inspiré
pour faire la déco de mon " Dopp " . Comme celle du C-800 . Quand on aime.....    Quand je reprendrais la construction du MU 13 D-2 , elle sera a nouveau presque identique mais avec le drapeau Français sur la dérive .
Alain A+ |
