Adler Fidèle Posteur
Posté le: 04/10/2013 10:17 Sujet du message: Prerov |
Hello,
So I started a new project: Přerov (as. Hol's der Teufel)
Wingspan 4200 mm
The glider built according to the plan Teufel in the village Prerov, Czech Republic.
Peter
Posté le: 04/10/2013 16:11 Sujet du message: |
Ahoj Petr,
Nice project we follow with interest
michel Serial Posteur
Posté le: 04/10/2013 17:20 Sujet du message: |
Michel |
Posté le: 04/10/2013 17:32 Sujet du message: |
Posté le: 24/10/2013 17:34 Sujet du message: Re: Prerov |
Hi,
Work on the hull gliders continues. I would like the fuselage overlaid plywood.
It will great. Everything I draw myself.
Posté le: 25/10/2013 19:22 Sujet du message: |
Posté le: 08/12/2013 14:33 Sujet du message: Re: Prerov |
Hello,
work continues on the fuselage glider. I have done ribs wings.
The fuselage will put a cover 0.4 plywood.
Petr |
Jodelfreak Fidèle Posteur
Posté le: 08/12/2013 16:54 Sujet du message: |
schönes Projekt!!!
Suche/Habe Zeichnungsunterlagen vom Rhönadler35 |
Posté le: 08/12/2013 16:58 Sujet du message: |
Ahoj Petr, always neat and clean as usual
The weather at Rokycany is not too cold?
Posté le: 08/12/2013 19:00 Sujet du message: |
Hi Vincent,
thank you for the compliment.
The weather is nice here. It's not too cold. Today it 2-3 Celsius.
What project you prepare? What will be new?
Peter |
de plancke Incurable Posteur
Posté le: 20/01/2014 18:12 Sujet du message: Re: Prerov |
Hello,
Continuing in the works.
Fuselage-cover plywood 0.4.
I started construction of wings.
Posté le: 20/01/2014 18:46 Sujet du message: |
Posté le: 21/01/2014 15:11 Sujet du message: |
yes beautiful ladies ... "nose art" or "backside art" ??? |
Posté le: 17/02/2014 09:58 Sujet du message: Re: Prerov |
Hello,
So I turn a little further in the construction of a glider. Spring is coming and I have done
Petr
Posté le: 26/06/2014 10:03 Sujet du message: Re: Prerov |
Hello,
I finished the Czech Hols der Teufel. These gliders are built in Czechoslovakia often enough.
Now I am waiting depends on the reel. The reel has a friend Jindra Stejskal.
Awaits us test flying the new gliders.
Petr
RichardP Accro Posteur
Posté le: 26/06/2014 13:51 Sujet du message: |
très joli
Posté le: 26/06/2014 17:00 Sujet du message: |
Très réaliste le pilote.
Michel |
LV Maniaco Posteur
Posté le: 26/06/2014 17:43 Sujet du message: |
Petře, krásna práca ako je u teba vždy dobrým zvykom...
Kedy krásavca uvidím vo vzduchu?
Laco |
Posté le: 26/06/2014 19:25 Sujet du message: |
Ahoj Laco,
díky.Musím napřed zálet.Prubnu ho na navijáku Jindry.Uvidíme.
Moc se mi líbí tvoje nová prvoválečná vlečná.
Ahoj. |
Peter64 Maniaco Posteur
Posté le: 27/06/2014 07:49 Sujet du message: |
Hello Petr,
verry good design and deco.
Congratulation .
Greetings
Peter |
Posté le: 27/06/2014 22:08 Sujet du message: |
Ahoj Petr!
beautiful glider you built!
Hope you can soon take a lot of pictures of small and big Prerov.
Will you have the Prerov with you at the meeting in July?
Ahoj,
Posté le: 28/06/2014 07:21 Sujet du message: |
Hallo Petr,
sehr schön sauber gebaut - Glückwunsch zu diesem Flugzeug
Besonders sauber auch die patinierten Holzflächen
Gruß Johannes |
