Adler Fidèle Posteur
Posté le: 06/01/2015 16:30 Sujet du message: Grüne Post |
Hello,
I started the construction of a German glider Grüne Post. The model is from the kit Hexe Model. I have done partly fuselage. Construction of a model is pleasant and goes quickly.
Petr
Posté le: 15/01/2015 13:52 Sujet du message: Re: Grüne Post |
Greetings,
continuing with the construction of a German glider Grüne Post. I work on the fuselage of the glider.
The cover is 0.6 mm plywood.
Posté le: 23/01/2015 15:41 Sujet du message: Re: Grüne Post |
Hello,
I also made some progress in construction. I finished rudder. I shaded it before coating. Little did I suggested interior.
Petr
Tatodesign Apprenti Posteur
Posté le: 02/02/2015 11:05 Sujet du message: |
Hi Petr,
congratulations, neat work!
I will follow you with interest, I have too the HEXE short kit
and I will start it as soon as I finish the painting of a big ME 262 for a friend |
Posté le: 03/02/2015 09:53 Sujet du message: |
Hello,
Thank you. Construction of a model is quick and easy. You will be satisfied. In two days I have almost finished wings. I will now be coated plywood 0.6.
Petr
Posté le: 05/04/2015 19:26 Sujet du message: Re: Grüne Post |
Greetings
I continue building Grüne. I finished fuselage. The cover will be Solartex.
Fuselage, I modified a bit.
Petr
Posté le: 06/04/2015 10:57 Sujet du message: |
RichardP Accro Posteur
Posté le: 06/04/2015 11:52 Sujet du message: |
nice building
Posté le: 04/06/2015 21:15 Sujet du message: Re: Grüne Post |
Hallo,
Today we are in our at the airport for the first time flying the new gliders. Grüne Post and Krajánek. Everything managed to. Two towing flying constantly. Nice weather.
Here are the photos.
http://rcmpilot.rajce.idnes.cz/Aerovleky_4.6.2015/
Petr
Posté le: 04/06/2015 22:06 Sujet du message: |
H Petr,
die Holzoberfläche sieht super aus
Johannes |
Erix Fidèle Posteur
Posté le: 05/06/2015 10:55 Sujet du message: |
Ahoj Petře,
Krásné probarvení, vyniká konstrukce. No je poznat PAN maketář. Ať ti slouží.
P.S. Ta dvouocasá/dvousměrovková vlečná je móóóóc hezká. Kdo je prosím majitel/stavitel.
Erix |
Posté le: 06/06/2015 17:23 Sujet du message: |
Ahoj Eriku,
poslal jsem Ti mail. Děkuji,snažil jsem se. Líbí se mi ta velikost.Třímetrovka,celkově robustní ale skladné do auta.
Petr  |
CHAUSSEBOURG Maniaco Posteur
Posté le: 06/06/2015 18:53 Sujet du message: |
Very good pictures . The Zlin 24 does not look very different from my Castel 3010.
LDC |
LV Maniaco Posteur
Posté le: 18/06/2015 18:41 Sujet du message: |
Hello Stefano,
On covering of the wing I used balsa. The wings are colored. I gliders fuselage covered with plywood.
Petr
Posté le: 18/06/2015 20:01 Sujet du message: |
Sehr schön geworden Petr
Ich wünsche Deiner Post und Dir immer gute Flüge und noch bessere Landungen
Johannes |
Posté le: 22/06/2015 16:50 Sujet du message: |
« Adler » a écrit: Hello Stefano,
Petr
Good idea!
Really a nice work, congratulations! We will see it and meet you at Wasserkuppe?
best regards
Stefano |
Posté le: 22/06/2015 19:50 Sujet du message: |
Hi Stefano,
Thank you. On Wasserkuppe unfortunately I will not. I missed to log on time.
I have a nice flying, and weather.
Petr |
carlominimoa Stagiaire Posteur
Posté le: 23/06/2015 15:27 Sujet du message: |
Hello, I'm just approaching the wings and I don't understand the first three root ribs how they do the dihedral...is there any diehedral in this model?
Because from the three view I don't see any!!
Please Help me to understand also with some photos.
Tnx
Carlo |
Posté le: 24/06/2015 15:27 Sujet du message: |
EXCELLENT !!! ![[good]](images/smiles/good.gif)
