awiatik Stagiaire Posteur
 Posté le: 03/12/2016 14:57    Sujet du message: MIS, glider of 1925 |
After a long break, I decided to build another model mini glider.
The choice fell on the Polish glider from 1925: MIS.
Constructor of the glider was Michal Bohatyrew.
The documentation is fairly modest, a few photos and a plan from the book:
Polskie konstrukcje lotnicze tom.1
The model has to be 1/10 scale which will have a span of one meter, 60 cm
in length.
Painting: and here is the problem, because according to the monograph Polskie Konstrukcje Lotnicze tom.1 fuselage will be painted in red, and below another proposal painting.
Regards
Kostek |
 Posté le: 03/12/2016 15:42    Sujet du message:  |
Hi Kostek
Very interesting glider   you will build it with the skids or wheels?
 Posté le: 03/12/2016 17:36    Sujet du message:  |
        bon choix
Dominique |
 Posté le: 03/12/2016 23:49    Sujet du message:  |
Vincent,
I do not know: the wheels or skids. But I think they will wheel.
DOMINIQUE,
thanks
Construction of the model started.
the sides the fuselage balsa 1.5 mm
Kostek |
 Posté le: 04/12/2016 17:33    Sujet du message:  |
Construction continued.
Regards
Kostek |
michel Serial Posteur
 Posté le: 04/12/2016 18:05    Sujet du message:  |
 Posté le: 05/12/2016 14:38    Sujet du message:  |
The next step: tail.
wing ribs already cut
Regards
Kostek |
 Posté le: 09/12/2016 21:25    Sujet du message:  |
Continued construction of model wing and complete the fuselage.
The next step is: total coverage of Japanese paper, painting the fuselage and signs.
Regards
Kostek |
 Posté le: 17/12/2016 21:03    Sujet du message:  |
Another photo of model building. Construction is slowly coming to an end.
Model almost finished, yet remained a few small items.
Regards
Kostek |
 Posté le: 21/12/2016 14:37    Sujet du message:  |
Model complete, and even made the first flights.
Model weight 260 grams. the bearing surface of about 19 dm2, or a little more than a model class F1H. This means that the model should fly well in thermals.
And a short video from the test flight.
https://www.youtube.com/watch?v=wy5IcUNo4Fc&feature=youtu.be
40/5000
And now I can think of a new model.Maybe you have any suggestions?
Regards,
Kostek |
 Posté le: 21/12/2016 17:49    Sujet du message:  |
Congratulations Kostek, great test flight   That's a good model to fly on a little slope.
milo Apprenti Posteur
 Posté le: 28/01/2017 20:19    Sujet du message:  |
Super model. Może pochwalisz się u nas na forum /ADW/
   pozdrawiam
milo
https://gliders.pl/ |
