Storch V
Adler
MessagePosté le: 19/03/2019 09:44    Sujet du message: Storch V Répondre en citant
Hello, colleagues.
Please do not know how to find the center of gravity of Storch V?
Is there a program to calculate? [humm]
Please owner of this model for advice.
Thank you.
Petr
Olli
Âge: 56 Verseau
MessagePosté le: 19/03/2019 14:29    Sujet du message: Répondre en citant
Hello Petr
which profile did you take [humm]
that's what matters Wink
Best Regards Olli
Adler
MessagePosté le: 19/03/2019 15:02    Sujet du message: Répondre en citant
Hi Olli
Profile is my own similar to Clark (slightly autostable)
Diff. 3000mm
I have already calculated according to the gravity of the program.
But I still prefer to hold consultations with other owners.
Regards
Petr
Olli
Âge: 56 Verseau
MessagePosté le: 19/03/2019 18:41    Sujet du message: Répondre en citant
Hi Petr,
waht ist the Profile on wing tip [humm]
see the Report at Walter
http://www.retroplane.net/forum/viewtopic.php?t=2138&postdays=0&postorder=asc&start=0
a program for calculating the center
http://www.mfc-reichertshofen.de/images/Schwerpunkt/WinLaengs4/W_Laengs4_v32.zip
Adler
MessagePosté le: 21/03/2019 07:48    Sujet du message: Répondre en citant
Hi,
Thank you very much for the information. I appreciate it.
do both rudders have the same flight deflection?
Thank you very much. Very Happy
