bocorvin Maniaco Posteur
 Posté le: 28/09/2019 19:45    Sujet du message: repairing Nemere scale 1:6 |
Bonjour a tous,
Last weekend we had a tow meeting in Kampen
https://www.modelbouwforum.nl/threads/sleepmeeting-21-september-2019-bij-mvc-cumulus-kampen.266377/page-3
We had a magnificent day and the Fokker FG-2 and the Nemere made a lot of very nice flights.
With the first flight the Nemere refused to uncouple, so it made some hefty moves before I could fly it home with the tow line dangling at its nose. The Nemere has a carbon wingjoiner and I forgot the warnings of Philippe (Clifton) about carbon wingjoiners, so I didn't check. A couple of flights later I steered quite badly and I had to uncouple at 200m. Immediately after the uncoupling both wings came loose, taking the horizontaql stabilizers also off. The fuselage went down like an arrow and I thought; thats the end of the Nemere. We (some collegues helped) started to collect the stuff, it was a windy day and the grass was high, so it was difficult to find the remains. First we found the fuselage and to my disbelief, only the cockpitpart was demolished, the tail was in perfect order
It took a couple of hours and then we had collected both wings, stabilizers.
I started to clean up
I had to make two new frames, laminated from strips of 0.6mm ply
using the same techniques as in the original building
I repaired the stingers with scarfed joints
replaced the nose section, using the keelbeam as reference
I glued the interior back in, puzzled how I made it a couple of years ago
Glued new panels on the uotside
I use fineer for the covering of the nose
Next is the staining of the ply and the cockpit, I still have the mold
To be continued,
Vincent
 Posté le: 29/09/2019 08:26    Sujet du message:  |
Dear Vincent,
Your repair job is as good as your constructions skill.
It will probably be stronger then your original construction. And nobody will see the difference.
By the way you had beautiful pictures from your camera.
I wish a god repair.
Harold |
 Posté le: 29/09/2019 09:32    Sujet du message:  |
Schade, Vincent das deine Nemere kaput gegangen ist
Ich finde es aber sehr schön das du das tolle Flugzeug
wieder aufbaust
Liebe  Grrüße aus dem Südwesten
(Komisch  Es geht nur Güße oder Grrüße  , ein R will er nicht   )
 Posté le: 29/09/2019 11:08    Sujet du message:  |
Dear Harold,
Thanks for your nice comments   .
Clifton warned for the carbon wingjoiners, I didn't checked it, pity.
I'll make a different wingjoiner, carbon tube with steel as safety or massive steel (thats very unforgiven with hard landings), so I still doubt.
Danke Johannes fur die aufbauende worte   .
Wir haben anderhalb stunde nach die letzet Flugel gesucht, wenn wir die nicht gefunden hatte,   . Glucklich war nur die  rumpfnase zerstort, nach ein fall von 200m, Ich war erstaunt.
Ich habe Niederlandische wie heist das "spellingscontrole"   gibts andere probleme.
LG,
Vincent |
 Posté le: 07/04/2020 11:22    Sujet du message:  |
Bonjour a tous,
Some time ago I had the canopy glazing vacuum formed, so I could finish my Nemere. I planned to do the finish of the ply at the same time as my Gull.
I tinted it with bister (bistre en Francais) a water soluable pigment. After applying it with a brush, I spread it more evenly with a sponge
I put on two layers of porienfuller and finally a coat of PU boat varnish
In the meantime I laminated (same method as the frames) the support structure of the canopy, a fiddley job......my powerfile came in handy
    tinted it a stronger bister solution
    glued on the glazing in one piece (I found it difficult to get a good fit    ) and put the instrument panel in
    The repaired pilot (new feet) fitted in (he lost his sunglasses, they are not yet replaced).
Adri made new decals and  a new wingjoiner (8mm steel    ) was fitted. There where some small thing to fix at the wing and stabilizer, but everything worked and it came together nicely
Now I have to wait for better times to fly her.
Vincent (DB) |
 Posté le: 07/04/2020 12:04    Sujet du message:  |
Hallo Vincent,
ist ja wieder richtig schön geworden
Besonders auf dem vorletztem Foto sieht sie aus wie eine
richtig große
Wird Zeit das man wieder fliegen kann
LG Johannes
 Posté le: 07/04/2020 12:16    Sujet du message:  |
Danke Johannes,
Ja es wird zeit uw wieder zu fliegen, aber wir mussen warten....
So einer halbe stunde her war eine Mowe in kreisflug unter die Wolken....dann komt die lust zum fliegen stark zuruck
LG
 Vincent (DB) |
hermann Maniaco Posteur
 Posté le: 07/04/2020 13:34    Sujet du message:  |
Hallo Vincent
Wunderbare und schöne Realisierung.
Noch ein Segelflugzeug muss warten auf die Genehmigung zum Fliegen.
Wir mussen geduld haben, wir sind noch nicht mit der Quarantaine ferordung fertig und es wird lange dauern.
Bis bald, hoffe ich.
Charles |
 Posté le: 07/04/2020 13:52    Sujet du message:  |
Hallo Charles,
Danke fur die komplimenten
Ja Ich habe geduld und glucklich ein ganz schonen hobby   .
Wenn die Quarantaine leichter ist gibt wahrscheinlich viele erstfluge
Hoffentlich auch bis bald,
Vincent (DB) |
 Posté le: 15/05/2020 12:13    Sujet du message:  |
Hello everyone,
This week the quarantine (confinement) was loosened, we could use the field again   . We had to keep 1.5m distance from each other. On some photo's it looks closer, but that's due to Raymonds tele photolens., It was blowing harder than predicted and the sky was exceptionel clear. It resulted in some very nice shots taken by Raymond (Fotor).
   Always gusts at inconvienient moments
    After this scary start it was wunderful to fly the Nemere again (with a steel wingjoiner     )
It was a bright day and the sunlight through the wings was so nice.
    The Nemere is such a nice clean glider
Its a good feeling that the Nemere is flying again, I hadn't expected that when she came down last year, lovely to see her fly again
Vincent.  (DB) |
Sed Maniaco Posteur
 Posté le: 15/05/2020 18:45    Sujet du message:  |
Congratulations Vincent          ! You did a fantastic job for this repair with courage and patience ... Your glider is also very beautiful in flight and it is a fair reward for your work. I wish you many more flights    .
   Serge |
 Posté le: 15/05/2020 19:58    Sujet du message:  |
Toll das du, lieber Vincent ,
die Nemere wieder so schön aufgebaut hast
Und das Ergebniss, ist wie schon früher, ein Traumflieger
Weiterhin viel Spaß beim Fliegen und immer heile Landungen
Liebe Grüße
GARCIA Psycho Posteur
 Posté le: 16/05/2020 06:30    Sujet du message:  |
Belle réparation    ![[amen]](images/smiles/amen.gif)
   José |
 Posté le: 16/05/2020 09:37    Sujet du message:  |
Thanks Sed, danke Johannes et merci José for your nice comments
I still have the picture in my mind of the collapsing plane coming down, didn't expect at that moment that it should ever fly again!
Vincent (DB) |
