bocorvin Maniaco Posteur
Posté le: 15/04/2020 12:20 Sujet du message: |
Danke Olli, ja Ich war ganz gut gelaunt wenn die Querruder gut functionierten
I go on in English, the Gull is completed on the outside,the sun was shining, so I took the Gull outside for some pictures
 Adri made the name and the numbers on the wing, registration letters were not needed at that time
 You can see at my face (straight in the sun) that the Gull is quite heavy
Some detailing of the cockpit is still to be done.
Vincent (DB)
Franco Vallari Apprenti Posteur
Posté le: 15/04/2020 13:20 Sujet du message: |
Formidable!!!! ![[clap]](images/smiles/Clap.gif) |
Sed Maniaco Posteur
Posté le: 15/04/2020 13:28 Sujet du message: |
Waouh, superbe ! Très belle finition !
Il ne reste plus qu'à prendre l'air !
 Serge |
Posté le: 15/04/2020 15:08 Sujet du message: |
Marvelous !
you are a strong men ! position of victory
keep cool, some weeks again…
Posté le: 15/04/2020 15:19 Sujet du message: |
Thanks Franco Sed and Sebastian, yes it was quite heavy and my wife didn't know my camera, it took some time
I am afraid it will take some time before we are allowed to fly again, but I'll keep you informed.
Amicalement,
Vincent (DB) |
caralp_laurent Psycho Posteur
Posté le: 15/04/2020 19:46 Sujet du message: |
Bravo Vincent, it's magnificent !
I knew we would have finished our gliders at the same time
Ready to go to the slope or field. We just Don't know exactly when it's possible...
Friendly
Sénèque |
Posté le: 15/04/2020 22:10 Sujet du message: |
Thanks Lolo for your comment!
Yes we have to wait, I am going to finish the interior
Vincent (DB) |
Greg Accro Posteur
Posté le: 16/04/2020 18:26 Sujet du message: |
Il est superbe, en vol ce sera un régal ...
Bon, on attend ![[argh]](images/smiles/argh.gif)
 Le vent se lève ..... |
Posté le: 16/04/2020 19:00 Sujet du message: |
Herzlichen Glückwunsch zu diesem tollen Modell
und danke für den interessanten Baubericht, Vincent
Jetzt wollen wir nur noch hoffen das sich die Situation um das Coronavirus
sich bald bessert und du das schöne Modell bald einfliegen kannst
Liebe Grüße und bleib gesund
Posté le: 17/04/2020 18:01 Sujet du message: |
Merci Greg und danke Johannes fur das commentar
Muss nur noch an dem Cockpit und Piloten arbeiten und dann warten ob besseren Zeiten fur die Erstflug....
LG und ja, bleibt gesund,
Vincent (DB) |
Eric Spore Incurable Posteur
Posté le: 17/04/2020 18:23 Sujet du message: |
Magnifique !
Encore un chef d'oeuvre ![[bave]](images/smiles/bave.gif)
Posté le: 17/04/2020 18:46 Sujet du message: |
Merci Eric, I am feeling humble from all those nice comments
It still didn't have its maiden flight, hopefully that will be less nervewrecking as with the Fokker FG-2.
Friendly,
Vincent (DB) |
ManfredNeu Accro Posteur
Posté le: 20/04/2020 10:10 Sujet du message: |
Hallo Vincent,
einfach klasse, das Modell. Und wie schwer ist es geworden?
Gruß Manfred |
Posté le: 20/04/2020 10:28 Sujet du message: |
Danke Manfred .
Leider ist sie schwerer geworden wie gepland. 5200gr im Gull I ausfuhrung (2X 10mm kohlefaser Flugelverbinder und Flugelstutszen?) oder 5600gr wie Gull II I met 2X 10mm stahl Flugelverbinder (ohne Flugelstutzen?). Bei ein Flugelflache von 95 dm2 gibt es ein belastung von 56 oder 59 gr/dm2. Vielleicht auch nicht slecht, weil wir nahe die kuste fliegen und immer viel wind haben.
LG,
Vincent (DB) |
Clifton Psycho Posteur
Posté le: 20/04/2020 14:00 Sujet du message: |
Ma-gni-fi-que !
Quel beau travail et c'est un très beau planeur que j'aime beaucoup . Bravo !
Posté le: 25/04/2020 09:23 Sujet du message: |
Merci Philippe et oui j'aime cette planeur aussi .
Je travaille maintenant a l'interieur, mais il n'y a pas beaucoup d'information, helas.
Vincent (DB) |
Posté le: 29/04/2020 15:03 Sujet du message: |
Bonjour a tous,
Some time ago I had already made the head, ( see page 7), helped by a nice tutorial https://www.youtube.com/watch?v=WlPYWe2bGUo
 from super sculpey. Its is made round a clump of aluminium foil on a wooden peg, which I later removed. I started painting it with acrylics, shortly after that my wife took it over ( I was quite pleased).
 This close it looks a bit exagerated, but I think a model needs that to look realistic. In the meantime I made a pair of sunglasses from hard brass wire, with glasses of an old polaroid one. I also made hands from super sculpey, reinforced with a copper wire (mains electric wire)
 The copper wire slides in a hole in the arm and glued with PVA
My sister Hans had finished the clothing, it fitted nicely, even his trousers were ironed
 His head is fixed on a wooden dowel, glued with PU in his hollow head
 The peg is secured with some velcro in his body, just to get some friction.
The pilot needed a harnass, which I could not buy at the time, so I made one of elastic band, stitched on some leather (again an old wallet) and I used brass bushes which go at servo's. It was toned down with an airbrush. The safety pin was bend and soldered from hard brass wire and some brass strip.
 Handle for the spoilers
 closure lock of the canopy
 release handle for the dolly
 leather pouches
 hinges for the rudder pedals, made from plasticard, with pins as bolts
 en all put together
 the middle steel wire with the red ball is the uncoupler. The pilots fits in
 and with a closed canopy
With the interior and pilot finished the Gull is now ready to fly, I just have to wait till its possible, just wait and see...
Vincent (DB)
Posté le: 29/04/2020 16:43 Sujet du message: |
Bravo Vincent, magnifiques tous ces détails et le modelage de ton pilote est très réussi ![[clap]](images/smiles/Clap.gif)
Posté le: 29/04/2020 17:10 Sujet du message: |
Merci pour les comments Vincent et Jenny fait la peinture de la pilote
Vincent (DB) |
Claude Moinier Apprenti Posteur
Posté le: 29/04/2020 19:31 Sujet du message: |
Prachtig Vincent ![[clap]](images/smiles/Clap.gif)
 I Fly without Engine
ClaudeM |
Posté le: 29/04/2020 21:14 Sujet du message: |
Dankje Claude, en nu nog vliegen!
Groet, Vincent (DB) |
Posté le: 29/04/2020 21:25 Sujet du message: |
Hi Vincent,
dein sehr schön gebautes Flugzeug wird duch die tolle Einrichtung
und den schönen Pilot unm noch einiges aufgepeppt - super
Gruß mit der Hoffnung das der Erstflug nicht
zu lange auf sich warten muss
Posté le: 30/04/2020 07:49 Sujet du message: |
Proficiat. Prachtig. En nu nog vliegen.
Mvg.
Harold |
Posté le: 30/04/2020 08:09 Sujet du message: |
Danke Johannes en Harold
Geduld fur die erstflug....
LG, met vriendelijke groet,
Vincent (DB) |
Posté le: 30/04/2020 15:56 Sujet du message: |
Superbe Vincent, j'adore ton pilote. C'est du beau travail !
Posté le: 30/04/2020 20:43 Sujet du message: |
Merci Philippe pour le pilote .
Le "tutorial" https://www.youtube.com/watch?v=WlPYWe2bGUo est tres bonne avec des instruction tres claire, malheureusement c'est en Anglais.
Amicalement,
Vincent (DB) |
Posté le: 01/05/2020 08:13 Sujet du message: |
Bonjour Vincent
Bravo l'intérieur est magnifique
tu es un vrai sculpteur, le pilote est super
je te souhaite bon vol
 michel |
Posté le: 01/05/2020 14:02 Sujet du message: |
Bonjour Michel,
Merci pour ton comments . Heureusement il y a du progress dans les pilotes!
On attend l'ouverture de site pour voler...
Vincent (DB) |
Posté le: 03/05/2020 11:19 Sujet du message: |
Hier stimmt einfach alles - Modell, Cockpit und das fliegende Personal. Wunderbar
Dann auf zum Erstflug
Gruß Manfred |
Posté le: 03/05/2020 22:24 Sujet du message: |
Hello Manfred,
Danke , und dann die Erstflug, soll leider noch ein bisschen dauern!
Gruss,
Vincent (DB) |
