Adler Fidèle Posteur
Posté le: 26/10/2022 13:35 Sujet du message: Hols der Teufel |
Hello,
I would like to introduce you to my new project.
This is a historic Hols der Teufel glider. (Přerov)
Size 4300mm.
It is a glider built in Czechoslovakia.
It is slightly modified from the original,
I already had this glider built and it flew beautifully.
I decided on a new build. This is a kit.
I'm at the beginning, but building a glider is not complicated.
Petr
Posté le: 26/10/2022 17:06 Sujet du message: |
Hallo Petr,
ein interessantes Vorbild hast du dir ausgesucht
Bitte berichte weiter vom Bau.
Wie schwer soll das Modell werden ? ca. 10 KG?
Posté le: 26/10/2022 18:57 Sujet du message: |
Hallo Johannes,
danke, das Gewicht beträgt 9 kg. |
Posté le: 26/10/2022 21:13 Sujet du message: |
Danke Petr
