bocorvin Maniaco Posteur
Posté le: 02/04/2025 15:58 Sujet du message: |
Bonjour a tous
When the weather was not good for flying, I assembled the Schweizer in the clubhouse in the hope that someone had a idea for the colour scheme. Fortunately, that turned out to be the case and Rob sent me a nice proposal. I discussed it with Claude and looked with Adri at how that could be realized. Fortunately, Adri still had a large piece of matte red adhesive foil and I could cut out the red stripes. First made a template from paper transferred that to plywood, cut and sand it. Adri digicrafted the logo for the rudder surface and plotted that with the registration and black lines .
Claude had a very good idea about the registration; the N (because it was mostly used in the US), followed by our year of birth
Claude's wife is going to make a nice shawl for the pilot, otherwise she will really get goose bumps.
Everything else works and it is ready for the first flight, always exciting. (Actually, most flights are exciting..)
Vincent |
Posté le: 02/04/2025 16:24 Sujet du message: |
Super ! sobre mais très réaliste !
et cette transparence qui laisse voir toute la structure c'est vraiment très beau
Have a nice flight now !
Posté le: 04/04/2025 09:13 Sujet du message: |
Hallo Vincent,
mal wieder: Ein traumhaftes Modell wieder erschaffen
Posté le: 04/04/2025 12:38 Sujet du message: |
Hallo Sebastian
Merci et oui les bandes rouges me plaise aussi!
Danke , vielleicht fliegt er ahnlich wie die Grune Post!
Amicalement, LG,
Vincent (DB) |
Posté le: 13/05/2025 11:49 Sujet du message: |
Bonjour a tous,
The SGU 1-19 had made its first flight. The prototypical tow hook didn't work as it should, but it flew well, that was nice.
The landing was not nice, I didn't wont to fly over the people. The steel tube is really strong, luckily. A (too small) aileron servo was damaged. So I had to replace the hook and aileron servo's, that will take some time.
The link to the video,
https://youtu.be/c8T_13t1haI
Vincent (DB) |
Posté le: 14/05/2025 07:33 Sujet du message: |
Puh - das war ein spannender Erstflug, Vincent.
Aber schön das es gut gegangen ist
Ich freue mich schon auf unser Wochenende
Posté le: 14/05/2025 12:28 Sujet du message: |
Bravo Vincent pour ce premier vol
Le crochet de largage du câble n'a pas fonctionné ? problème de servo ?
Posté le: 14/05/2025 13:59 Sujet du message: |
Danke Johannes, und die SGU ist, wie sagt mann das, ziemlich stark
Sebastian, I had some unreliabilty problems with my hook of the Nemere 330cm span, it was a miniature of the original one. So I change this coupling and the Nemere one for a piece of tube with a peg in it as in my Slingsby's
This hook never failed me and I hope the same for the future!
Vincent (DB) |
Posté le: 16/09/2025 11:16 Sujet du message: |
It took a while, but more flight(s) have been made.
To refresh what happened, the very first tow went up well, unfortunately the (scale) coupling did not disconnect properly resulting in a hard landing with the tow line still attached.
Because the ailerons have quite a bit of mass, an aileron servo broke.
At home I replaced the servos with larger ones and replaced the scale coupling with a tube with pin coupling.
That was quite a hassle because to build in. Unfortunately I don't have any pictures of that, busy with other things.
Recently, the SGU has made quite a few flights and turned out to fly well, a decent descent speed, a lot better than the Fokker FG-2.
On a tow meeting in Alkmaar, Sjaak (from EVA) took pictures, it shows well!
This link is to a YT video on which I put all the material I have, subtitles are in Dutch, sorry for that.
https://www.youtube.com/watch?v=znVIy4hqE3o
Vincent (DB) |
Posté le: 17/09/2025 13:02 Sujet du message: |
Hello Vincent,
nice flight
Ton crochet de remorquage n'est pas encore tout à fait au point mais en tous cas le vol est superbe !
Bons prochains vols à venir !!
Posté le: 17/09/2025 13:17 Sujet du message: |
Bonjour Sebastian,
Thanks for your comment
It is a bit confusing, the video is a combined one with all the footage I had. So the first flight is again in this video. I already made a new coupling which does its job OK
It was quite a hassle to get it in
Vincent (DB) |
