HW 4 FLAMINGO 1:3.5 SCALE
1, 2, 3, 4 Suivante
cw
Âge: 77 Sagittaire
MessagePosté le: 19/07/2009 21:40    Sujet du message: HW 4 FLAMINGO 1:3.5 SCALE Répondre en citant
Well, it looks like good building weather again. Blowing a gale here today, so I started cutting wood for the Flamingo. It has eveything I like: a gull wing, spoilers... and a wheel Very Happy Very Happy
cw
Âge: 79 Verseau
MessagePosté le: 20/07/2009 08:12    Sujet du message: Répondre en citant
Dear Chris,
Previous project not yet dry and you start already a new one. You intend to fly in September?
Seems to be an interesting subject.
Can you give some more details about this sailplane?
On the net I found a picture of one from Friedrichshafen exhibition?
http://myaviation.net/search/photo_search.php?id=01304533&size=large
Regards.
Harold
ultralajt
Nouveau messagePosté le: 20/07/2009 11:47    Sujet du message: Re: HW 4 FLAMINGO 1:3.5 SCALE Répondre en citant
« cw » a écrit:
... It has eveything I like: a gull wing, spoilers... and a wheel Very Happy Very Happy
You forget something!
It has elegance! [clap] [clap]
Mitja
Never try, never fail....
Christian_B
Âge: 72 Capricorne
Nouveau messagePosté le: 20/07/2009 18:10    Sujet du message: Répondre en citant
Harold,
I would say it is a Petrel on the picture in your link and not a Flamingo!
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 20/07/2009 18:14    Sujet du message: Répondre en citant
Elegance, yes...how could I forget!
Harold, I think that is a photo of Graham Saw's Petrel. The two gliders do look similar, but since Belair in the UK produced a kit for the Petrel, there are a lot of them about over here...!
cw
Nouveau messagePosté le: 21/07/2009 08:09    Sujet du message: Répondre en citant
Hi Chris,
The Flamingo is a beautiful and a quite unknown glider, good project ! [clap]
I'm fond of the Petrel. My mini 1/10 flies so good, I think I'm gonna build a bigger one. I've thought about painting it blue with a white nose, and then I see your photos, great !!
I've seen the videos of your's in flight, it's magnificent ! [amen]
Bye
Lolométéo
Nouveau messagePosté le: 21/07/2009 08:31    Sujet du message: Répondre en citant
Hi Chris
Nice project, the Flamingo attracted my interest when i discovered Martin Simons' books ; The same as you,this glider has everything I like !
best regards Marc
Nouveau messagePosté le: 21/07/2009 18:35    Sujet du message: Répondre en citant
« caralp_laurent » a écrit:
Hi Chris,
Bye
Lolométéo
take a look ! Isn't it pretty Wink
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 22/07/2009 21:44    Sujet du message: Répondre en citant
Yes Pat, that is very pretty...
Meanwhile, tonight I have finished cutting out all the fuselage parts...
(It still will not stop raining here Crying or Very sad
cw
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 23/07/2009 19:49    Sujet du message: Répondre en citant
Beautiful birth, beautiful project, Chris .
I like gull wing.
Chris, be my guest ... Today, it was almost 40 degrees C here Laughing
Cem Zırh
Fafnir
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 23/07/2009 23:47    Sujet du message: Répondre en citant
40 degrees? Too hot to build aeroplanes... Cool
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 24/07/2009 21:21    Sujet du message: Répondre en citant
OK, starting at the beginning, the 1st fuselage 1/2 shell is built up on the board...
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 25/07/2009 23:17    Sujet du message: Répondre en citant
Today, the other half of the fuselage is added...
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 30/07/2009 20:22    Sujet du message: Répondre en citant
To continue with the rear of the fuselage we need the tailplane...
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 02/08/2009 20:07    Sujet du message: Répondre en citant
Time now to make the smell that my wife hates... [argh]
Then, the wing joiner box: Two 14mm Graupner brass boxes set for the dihedral and with the boxes crossing over each other to get the maximum length
The completed box is temporarily offered up to the fuselage
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 05/08/2009 18:34    Sujet du message: Répondre en citant
Now the front end is completed...
It is time to work out how the tailplane will sit...
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 06/08/2009 22:18    Sujet du message: Répondre en citant
Time to make up the elevator...
The elevator is made slightly larger than the tailplane and then sanded to match it exactly...
Here the trailing edges are sanded down...
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 08/08/2009 22:28    Sujet du message: Répondre en citant
Before glueing on the lower CTP sheeting, the rudder cable guides must be set up...
Balsa on the inside helps the cyano to grip the guide cable...
Now the sheeting can continue... (by the way, I consider the blood on the fuselage to be good luck. I have bled over most of my models Very Happy )
cw
Nouveau messagePosté le: 09/08/2009 15:12    Sujet du message: Répondre en citant
Yes ! [good]
Good job, like the other times. [clap]
Lolométéo
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 10/08/2009 21:02    Sujet du message: Répondre en citant
Now it is time to make up the elevator actuator...
I have modified my system slightly: now, I make the inside square brass tube 2 sizes smaller than the outside one. This makes setting up much easier and there is less possibilty of the system binding or sticking...
cw
Walter L.
Nouveau messagePosté le: 12/08/2009 17:25    Sujet du message: Répondre en citant
Chris,
it´s a really nice project! I would like to build this beautiful glider too....
Do you have other documents about the original glider than those in Martin Simon´s book?
regards
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 12/08/2009 18:29    Sujet du message: Répondre en citant
No Walter, I have no other useful information. This time I am producing a plan for the Flamingo, which will be published by Traplet, probably sometime early next year. There will be a canopy available and also a kit of CNC cut parts...
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 14/08/2009 18:48    Sujet du message: Répondre en citant
The fuselage sheeting in CTP is just about complete...
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 15/08/2009 21:05    Sujet du message: Répondre en citant
Moving on now to the fin...
The fin is sheeted with 0.75mm CTP
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 16/08/2009 20:22    Sujet du message: Répondre en citant
The fin will fit thus...
Now for the rudder...
cw
Nouveau messagePosté le: 16/08/2009 21:49    Sujet du message: Répondre en citant
... your "building-speed" is amazing Chris Shocked
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 17/08/2009 23:36    Sujet du message: Répondre en citant
Stephan, the more you do, the less you have to think about it... Very Happy
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 18/08/2009 16:47    Sujet du message: Répondre en citant
Now that the tailplane/rudder/fin are completed...
It is time to complete the fuselage
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 20/08/2009 21:31    Sujet du message: Répondre en citant
The filling and sanding of the fuselage is coming along well...
The tail skid is lined with Lithoplate
Rear end just about complete Very Happy
cw
tibor kertesz
Âge: 33 Cancer
Nouveau messagePosté le: 21/08/2009 05:49    Sujet du message: flamingo Répondre en citant
helllo chris, the lithoplate seems to aluminium? or titanium?
1, 2, 3, 4 Suivante
Page 1 sur 4
