Rusjan Apprenti Posteur
Posté le: 05/06/2009 11:02 Sujet du message: Minimoa 1:3.5 |
Hello !
Here we go again ... my new project is Minimoa 1:3.5 by CW...
Started with fuselage and rudder.
This is how it looks now... next step is planking the fuselage...
Regards !
Uroš
Posté le: 05/06/2009 12:34 Sujet du message: Minimoa ! |
Vincent thanks for the links ... I 've been looking at cw building log on RC-groups (3rd Minimoa) but these two that you gave are ....
Regards !
Uroš |
Stephan Psycho Posteur
Posté le: 06/06/2009 10:08 Sujet du message: |
Hi Uros
great to be able to follow your building. That also proofs which huge communitiy Retroplane becomes, from all over the world
Cheers
Stephan |
Posté le: 11/06/2009 22:50 Sujet du message: Minimoa ! |
Some progress in past few days ...
epoxy resin and glass fabrics were put in the cockpit area
sanded before car filler was added
and sanding...
not finsihed yet, but prepared for further work
Regards !
Uroš |
Posté le: 27/06/2009 18:28 Sujet du message: Minimoa ! |
Some progress....
elevator
balsa ribs were removed
wheel already positioned
elevator on the fuselage
rudder still need some work
test pilot already inspecting
Regards !
Uroš |
Posté le: 26/09/2009 11:47 Sujet du message: Minimoa! |
Finally some progress...
Fuselage almost covered...
wing joiner mounted in the fuselage..
Al template for the ribs nad some already cut from plywood..
ribs on balsa sheet..
"Big Mac" ...
ribs finished...
Regards !
Uroš |
Posté le: 26/09/2009 14:21 Sujet du message: Minimoa ! |
Here we go ...
Regards !
Uroš |
Posté le: 26/09/2009 18:55 Sujet du message: Minimoa ! |
And here is the result of today's work ... 2 meters done, 3 to go ...
Regards !
Uroš |
Posté le: 29/09/2009 14:39 Sujet du message: Minimoa ! |
Still missing some three meters of wing , but slowly it looks like the real one ...
Regards !
Uroš |
Peter64 Maniaco Posteur
Posté le: 29/09/2009 16:14 Sujet du message: |
Hallo Uros,
it's locking good your Mini Moa , you work fast and cleanly.
Geetings Peter |
Posté le: 30/09/2009 12:10 Sujet du message: |
Hallo Uros,
thank you for the compliment, for this time I make the varnishing by the fuselage and the wings.
Uros what material you want to use covering for your wings and empennage?
Greetings Peter |
Posté le: 30/09/2009 13:18 Sujet du message: Minimoa ! |
I was thinking about oratex, since I have good experience with it from my previous project. Fuselage will be probably painted in a "CW " way.
Regards !
Uroš |
Posté le: 15/10/2009 20:04 Sujet du message: Minimoa ! |
Some more progress...
tow hook...
from inside...
some more work done in wing-fuselage area...
prepared for finsh...
Nose still needs to be closed. Models for nose weights are already prepared and will be casted as soon as plaster moulds dry out.
Regards !
Uroš |
Posté le: 18/10/2009 17:36 Sujet du message: Minimoa ! |
Today some work was done on the air brakes...
Regards !
Uroš |
Posté le: 28/10/2009 20:46 Sujet du message: Minimoa ! |
Some more work done ...
the garden looks rather small now ...
Regards !
Uroš |
Klaus69 Apprenti Posteur
Posté le: 29/10/2009 08:43 Sujet du message: |
Well done! It looks realy nice. Hope we will see pictures from the maiden flight |
Posté le: 29/10/2009 10:35 Sujet du message: |
Hallo Uros,
perfect work that you have made, .
Geetings Peter |
Posté le: 29/10/2009 20:14 Sujet du message: Minimoa ! |
Thanks, guys ... There will sure be some more photos and hopefully also the video of the maiden flight ...
Regards !
Uroš |
Posté le: 04/11/2009 21:29 Sujet du message: Minimoa ! |
Lead weights in the nose...
and finish...
Regards !
Uroš |
Posté le: 05/11/2009 20:21 Sujet du message: |
Hallo Uros,
tell me please, how much gram are the weight in the nose?
Peter |
Posté le: 05/11/2009 20:57 Sujet du message: Minimoa ! |
Hello Peter !
All 4 pieces are just a few grams below 1kg...
Regards !
Uroš |
DirkBoehm Apprenti Posteur
Posté le: 05/11/2009 21:50 Sujet du message: |
Hello Uros,
beautiful piece of work, that you present here.
I love those gullwing sailplanes.
Keep up the good work and let us know about any progress.
Cheers,
Dirk.
BTW: Almost as impressive as the Minimoa is your lawn. Nice grass, just like on a golf course. I wish mine would look half that good
Viele Grüße,
Dirk. |
Posté le: 02/12/2009 08:54 Sujet du message: Minimoa ! |
Wings are almost ARC ... Still some work sould be done on the wing tips and front end of the wing...
Regards !
Uroš |
Posté le: 25/02/2010 14:21 Sujet du message: Minimoa ! |
Almost finished ... There is still some work regarding fuselage but I hope it will be done in next days...
Regards !
Uroš
Posté le: 25/02/2010 20:37 Sujet du message: |
Salut Uros,
your glider looks like perfect .
congratulations
Peter |
cw Accro Posteur
Posté le: 25/02/2010 23:42 Sujet du message: |
Nice job, Uroš...
cw |
