czirh Accro Posteur
 Posté le: 19/10/2009 14:54    Sujet du message:  |
I think bell crank sistem..?    Because, this place very small..?
   Cem Zırh
Fafnir |
 Posté le: 19/10/2009 15:06    Sujet du message:  |
| Hi Cem, sorry but I don't know what is "bell crank system" you want to have an idea to make link to the rudder with cables? or a system for the elevator? |
czirh Accro Posteur
 Posté le: 19/10/2009 16:35    Sujet du message:  |
Very small place and need to be strong    perhaps you can get tips and inspiration with the system on the RRG Professor  http://www.retroplane.net/forum/viewtopic.php?t=2028
If it was for me, I build a system with ball bearings |
czirh Accro Posteur
czirh Accro Posteur
 Posté le: 21/10/2009 13:35    Sujet du message:  |
Thank you, Christian..
   Cem Zırh
Fafnir |
czirh Accro Posteur
 Posté le: 21/10/2009 13:43    Sujet du message:  |
This is (my.!)  bell crank system..
It is work, but not rugged now...!
   Cem Zırh
Fafnir |
tuzkanh Stagiaire Posteur
 Posté le: 21/10/2009 17:27    Sujet du message:  |
| Abi çok güzel gidiyor kolay gelsin |
czirh Accro Posteur
 Posté le: 21/10/2009 18:42    Sujet du message:  |
Hi Hakan, welcome to the forum, welcome to the Turkey   |
 Posté le: 21/10/2009 19:46    Sujet du message:  |
Cem abi teşekkür ederim
Thank you Vincent |
czirh Accro Posteur
czirh Accro Posteur
 Posté le: 23/10/2009 15:21    Sujet du message:  |
skid making..
   Cem Zırh
Fafnir |
czirh Accro Posteur
 Posté le: 25/10/2009 14:05    Sujet du message:  |
release system:
servo: robbe-futaba s9202
   Cem Zırh
Fafnir |
czirh Accro Posteur
 Posté le: 26/10/2009 18:09    Sujet du message:  |
fuselage  construction..
   Cem Zırh
Fafnir |
 Posté le: 26/10/2009 18:43    Sujet du message:  |
Bonne construction Cem
It's very interesting your release system ![[good]](images/smiles/good.gif)
czirh Accro Posteur
 Posté le: 29/10/2009 10:18    Sujet du message:  |
What is the simplest method of this cutting process?
Thanks..
   Cem Zırh
Fafnir |
 Posté le: 29/10/2009 10:48    Sujet du message:  |
Hi Cem
You can cut with a small blade of electric saw in a X-Acto or a diamond disk
But me, I prefere to cover the fuselage without the canopy, and build and adjust the canopy in a second time...
czirh Accro Posteur
czirh Accro Posteur
 Posté le: 29/10/2009 18:17    Sujet du message:  |
Joiner tube..
   Cem Zırh
Fafnir |
czirh Accro Posteur
 Posté le: 30/10/2009 18:19    Sujet du message:  |
wing&fuselage connection
   Cem Zırh
Fafnir |
Lothar Mentz Accro Posteur
 Posté le: 31/10/2009 10:26    Sujet du message:  |
Hi Cem,
it's a beautifull glider and a great job You are doing.
Thank You for this detailed build-log.
Regards
Lothar
czirh Accro Posteur
czirh Accro Posteur
 Posté le: 31/10/2009 15:54    Sujet du message:  |
Today I made a simple stand for Fafnir. This is very important.
   Cem Zırh
Fafnir |
 Posté le: 31/10/2009 17:28    Sujet du message:  |
   With that, it is more easy to work on the fuselage, we should make everytime a stand in first.
 Posté le: 31/10/2009 20:36    Sujet du message:  |
Cem abi çok iyi gidiyor kolay gelsin
   Hakan Tuzkan
Ankara/Türkiye |
jorge antonio Stagiaire Posteur
 Posté le: 01/11/2009 02:50    Sujet du message:  |
Hi Cem,
Beautiful bird, congratulations for the construction.
Jorge ![[clap]](images/smiles/Clap.gif)  |
czirh Accro Posteur
 Posté le: 01/11/2009 19:05    Sujet du message:  |
Elevator servo: Hextronik HX12K
Type: Digital
Gearing: Metal
Weight: 55g
Size: 40.7 x 19.7 x 42.9mm
speed (4.8v): 0.17sec/60degrees
speed (6.0v): 0.13sec/60degrees
stall torque(4.8v): 13kg/cm
stall torque(6.0v): 15kg/cm
Temperature Range: -30 to +60 Degree C
Dead Band Width: 4usec
   Cem Zırh
Fafnir |
czirh Accro Posteur
 Posté le: 05/11/2009 21:36    Sujet du message:  |
Good evening,
Fafnir procekt will delay. My right leg broke from two points. Operation tomarrow morning.
   Cem Zırh
Fafnir
 Posté le: 05/11/2009 21:50    Sujet du message:  |
Aïe, it's bad news, I hope that your operation will be good
Amicalement,
