cw Accro Posteur
 Posté le: 18/11/2009 20:01    Sujet du message:  |
Harold, there was quite a lot of wind that day, maybe 25Kph, and it was sometimes gusty near the ground (where I like to fly   ) There is no instability in the model's handling, as perhaps the stall demonstrates?
The HQ35 section has good penetration, even with 14% at the root. The only downside at the moment lies in the ineffectiveness of the spoilers, but that will be cured by programming more up-aileron in the Tx.
I'm still using the Flycamone2, but with the 1000Mah Extreme clip-on battery, which cures all the problems the camera had previously...
   cw |
Orionis Incurable Posteur
 Posté le: 19/11/2009 08:48    Sujet du message:  |
Congratulations for this flight and the video (and music) quality!
   Fabrice |
 Posté le: 19/11/2009 10:33    Sujet du message:  |
On the Sohaj, 3.75 m, weight less then 5 kg, I have the HQ 3.15 – 12 wing section.
After long trials and problems in the beginning, because of wrong thrust line adjustments, it is now flying perfectly.
I confirm, this is really an excellent section for our gliders. It can be used for low and fast speed. Penetration also is excellent.
Your Flamingo is larger and I can understand that 14% is better adapted.
Harold |
Zeitweise Stagiaire Posteur
 Posté le: 20/11/2009 20:46    Sujet du message: Re: HW 4 FLAMINGO 1:3.5 SCALE |
Hi Chris,
where did you find the photos and records about this beautiful bird? I only found pictures of an earlier version....
Regards
Alexander |
cw Accro Posteur
 Posté le: 20/11/2009 21:28    Sujet du message:  |
Alexander, all I have is the information in Martin Simons' book, 'Sailplanes 1945-65'. After that, I used my imagination
   cw |
 Posté le: 20/11/2009 21:57    Sujet du message:  |
Dear Chris,
I only found these pictures on the Internet, seems to be an early version...
Regards
Alexander |
cw Accro Posteur
 Posté le: 20/11/2009 22:15    Sujet du message:  |
Yes, Martin sent me these pictures too... I think this is the Flamingo some years later with some terrible modifications to the canopy. I was happy to go by the 3-view drawings in the book instead!
   cw |
 Posté le: 09/12/2009 12:03    Sujet du message: Flamingo Tailplane |
By the way please notice the nice glider (twoseater) on the left is a Spallinger S25!
Regards
Alexander |
caralp_laurent Psycho Posteur
 Posté le: 09/12/2009 14:33    Sujet du message:  |
Hi Chris,
congratulations for your new super glider !
And thank's for sharing your video with us, it shows many other magnificent gliders.
The slope seems to be great, too !
Bye
Lolométéo
   Lolométéo, rétro addict  ;o)
Sénèque |
cw Accro Posteur
 Posté le: 09/12/2009 19:19    Sujet du message:  |
Thank you for the information Alexander: I can believe the cockpit being modified at some stage, but probably not the position of the tailplane...never mind
The Spalinger 25 is on my list too...!
Laurent, global warming has been kind to us this year, bringing back the westerly winds...
   cw |
 Posté le: 10/12/2009 11:31    Sujet du message:  |
	« cw » a écrit: 	... but probably not the position of the tailplane...
Salü Chris!
No of course the elevator was not changed. It seems the original and the 3-side view have a few differences. Obviously they wanted to build a modified Fafnier and changes of 10 years flying were applied: an additional wheel, an elevated tailplane and so on.
If your model flies well of course no problem! (You also changed the Gö profil, hehe).
Alexander |
