Petrel CW 1:3,5
Aller ŕ la page Précédente
MessagePosté le: 18/02/2010 09:53    Sujet du message: Répondre en citant
Hello Wolfgang, I don't remember where I found it, certainly on scalesoaring.co.uk
enclosed in hight resolution and the view of the real size
 Taille du fichier:  203.6 Ko
 Vu:  785 fois
Wolfgang
Âge: 67 Poissons
MessagePosté le: 18/02/2010 10:07    Sujet du message: Répondre en citant
Thank you Vincent
cw
Âge: 78 Sagittaire
MessagePosté le: 18/02/2010 19:51    Sujet du message: Répondre en citant
Wolfgang, you can download the more modern Slingsby logos here: http://www.silentflight.net/index.php?/content/view/86/69/
The older one is more difficult Sad
Have you seen the video of the full size Habicht where the drop-off wheels bounce back up and hit the tailplane? Shocked
http://www.scalesoaring.co.uk/Movies/Pathe/habicht-dolly.wmv
cw
cw
Âge: 78 Sagittaire
MessagePosté le: 18/02/2010 19:52    Sujet du message: Répondre en citant
Ah, Vincent...you are too quick [amen]
cw
Wolfgang
Âge: 67 Poissons
MessagePosté le: 19/02/2010 10:58    Sujet du message: Répondre en citant
The accident with the Habicht is the reason,why I want to have a control of the wheeldrop.The solution with a hole in the bottom of the fuselage would be easier to realise but not the save way.Therefore Iam looking for a mechanism .
MessagePosté le: 19/02/2010 12:58    Sujet du message: Répondre en citant
Don't worry about the bounce of the dolly, it happens raraely on the scale model due the nature of tyre ( less flexible as the reel ). With my Spalinger , I have one , and I never have had this kind of problem until now. Very Happy
Ok a release system for the dolly is the best and more realistic ( as the reel ), why not if you can do. Wink
MessagePosté le: 19/02/2010 14:26    Sujet du message: Répondre en citant
Absolutely the trolley will never bounce like a balloon as it did for the full scale Habicht..All what you risk is to damage your trolley if you release it too high. This is not to be understeemated as sometimes during take off sequence (for exemple: on side wind conditions with one finger on the transmitter switch to release the tow cable) one are busy enough at that time and then ....the trolley could be released with some delay.
Nice building [clap]
DirkSchipper
Âge: 68 Poissons
MessagePosté le: 10/03/2010 08:07    Sujet du message: Répondre en citant
[quote="Wolfgang"]The accident with the Habicht is the reason,why I want to have a control of the wheeldrop.The solution with a hole in the bottom of the fuselage would be easier to realise but not the save way.Therefore Iam looking for a mechanism .[color=white][/color][/quote]
Hi,
I recently found this (http://vdp63.free.fr/DG%20600.html).
Look at the last 2 pictures at the bottom.
Simple and effective it looks to me.
Greetings,
Dirk.
Wolfgang
Âge: 67 Poissons
MessagePosté le: 19/04/2010 06:56    Sujet du message: Répondre en citant
Da ich jetzt einige Zeit nicht weiterbauen konnte muss ich nun Gas geben
Also zuerst Farbe und Pistole herrichten
dannach Klarlack und abkleben für Farbe
Dannach Blaue Retrofarbe
und das Logo wird auf der Frühstückstasse auf Alltagstauglichkeit geprüft.
Wolfgang
Âge: 67 Poissons
MessagePosté le: 19/04/2010 07:04    Sujet du message: Répondre en citant
Hier das Foto von der Testtasse
MessagePosté le: 19/04/2010 07:29    Sujet du message: Répondre en citant
Servus Wolfgang,
...hübsch Deine Tas...ähhh...Petrel... [houla]
Bin schon sehr gespannt auf das Endergebnis. Hast Du die Slingsby Logos schon am PC? Falls nicht, bei Paar Deco in Innsbruck sollten die noch am Rechner sein - dort habe ich meine plotten lassen. Sehen sehr gut aus.
Vom alten Logo habe ich noch zwei oder drei Orginale - wenn Du da was brauchst einfach kurze Info.
Grüße nach Tirol Wink
Wolfgang
Âge: 67 Poissons
MessagePosté le: 19/04/2010 07:37    Sujet du message: Répondre en citant
Hallo Walter
Wie gross in cm sind denn Deine LOGOS ???
meines sollte 1:3,5 sein und hat ca. 3,6 cm Spannweite-hat mit Vincent geschickt als Datei-das Original hat also ca 12,6cm [img] [humm] http://www.retroplane.net/forum/images/uploads/Wolfgang/logo_slingsby_3_5_152.jpg[/img]
MessagePosté le: 19/04/2010 08:09    Sujet du message: Répondre en citant
Hallo Wolfgang,
...kann ich Dir am Abend schreiben - ich werd mal wühlen und meine Logos abmessen. Ein Bild sollte sich auch ausgehen.
Das Logo von Paar Deco ist bereits passend für einen Digitaldruck - den kannst Du in der Größe verändern (lassen). Sie sind selbstklebend und wurden klar lackiert.
Das Orginallogo kann man nur als Vorlage nehmen. Es sind Wasserschiebebilder die bei Slingsby verwendet wurden. Sie sind etwas vergilbt und ich weiß nicht ob man die noch verwenden kann. (Hab ich bei der VDC Rally in Wels erstanden.
Grüße
Wolfgang
Âge: 67 Poissons
MessagePosté le: 03/05/2010 06:38    Sujet du message: Répondre en citant
Noch ca. 2 Monate und ich muss fleissig sein.Hier die neuesten Fotos
MessagePosté le: 03/05/2010 06:43    Sujet du message: Répondre en citant
Hi Wolfgang, very beautiful [clap] I like the small sticker retroplane 2010 Laughing
see you soon Very Happy
MessagePosté le: 03/05/2010 08:04    Sujet du message: Répondre en citant
Very nice work indeed ; good luck for the maiden flight
MessagePosté le: 03/05/2010 17:17    Sujet du message: Répondre en citant
superbe, [clap] [clap] [clap]
MessagePosté le: 03/05/2010 20:34    Sujet du message: Répondre en citant
Hallo Wolfgang,
einen super schicken Oldie hast Du da gebaut,
deinen sauberen Cockpit Ausbau finde ich echt schick Very Happy Very Happy
Eine kleine Kritik möchte ich aber trotz dem ausüben,
die Schrauben der Instrumente hättest lieber etwas kleiner
wählen sollen. [humm]
Aber sonst [clap] [clap] [clap]
Wolfgang
Âge: 67 Poissons
MessagePosté le: 04/05/2010 07:00    Sujet du message: Répondre en citant
Habe gestern die Gurte fertig gemacht.
Ich kann nirgends in den Retroplanbildern( speziell in denen von Vincents Musgern) sehen,wie der fünfte Teil dieser Gurte aussieht bzw. funktioniert-nämlich der Verschluss.
Kann mir da jemand weiterhelfen???
Wolfgang
Âge: 67 Poissons
MessagePosté le: 04/05/2010 07:04    Sujet du message: Répondre en citant
Hallo Olli
Das mit den Schrauben ist so ein Problem-ich hab in Tirol einfach keine kleineren bekommen können.
Weisst Du ein Quelle -ich kann im Cockpit ja immer noch tauschen-sind ja blind im Holz des Armaturenbrettes verschraubt -ohne Funktion-also jederzeit ersetzbar.
MessagePosté le: 04/05/2010 07:16    Sujet du message: Répondre en citant
Hallo Wolfgang,
I am not sure to have understood your question but if it is to know how the stripes of the harness are linked , I have made this on the harness of the Hüter 17
MessagePosté le: 04/05/2010 07:21    Sujet du message: Répondre en citant
and the photo in the full scale
I hope like Marc it was the question... my friend google translator Laughing
Wolfgang
Âge: 67 Poissons
MessagePosté le: 04/05/2010 07:46    Sujet du message: Répondre en citant
Merci beaucoup
MessagePosté le: 04/05/2010 08:07    Sujet du message: Répondre en citant
Hallo Wolgang
das wird ein tolle Schmuckstück, Gratulation. Was den Verschluss angeht macht Vincent sie zum teil auch aus Sperrholz und lackiert sie dann. Ich werd nochmals ein Bild suchen.
MessagePosté le: 04/05/2010 17:41    Sujet du message: Répondre en citant
Hallo Wolfgang,
schau doch mal bei Ebay rein unter "Schlitzschrauben M2"
Walter L.
MessagePosté le: 11/05/2010 18:28    Sujet du message: Schrauben... Répondre en citant
Hallo Wolfgang,
ich mache es seit einiger Zeit immer so, dass ich kleine, meist elektronische Geräte, auseinander schraube, bevor ich sie wegwerfe. Die kleinen Schrauben verwahre ich dann (in der Hoffnung, mal genügend gleiche zu haben....).
Wolfgang
Âge: 67 Poissons
MessagePosté le: 25/05/2010 07:00    Sujet du message: Répondre en citant
Endlich fertig
Fehlt noch der Erstflug
MessagePosté le: 25/05/2010 09:26    Sujet du message: Répondre en citant
Hello Wolfgang, very beautiful, congratulation [clap]
did you retrieved hair of a doll for your pilot?
You will make the maiden flight before Wasserkuppe?
Wolfgang
Âge: 67 Poissons
MessagePosté le: 25/05/2010 09:57    Sujet du message: Répondre en citant
I will make the maiden flight next weekend.
The pilot in the Petrel will be another one-the pilot on the photo in the Petrel is that of my Nimbus 4 also 1:3,5- I am still producing the pilot of the Petrel and I want to make him a little more BRITISH- whatever that means- like the pilots in yout tandem tutor-bur I am not so good in making pilots)
For the hair I have bought a kind of plush fabric that you can stick on the head an then you have to cut it
like a coiffeur.
On thursday I will show you a photo
Nouveau messagePosté le: 25/05/2010 10:02    Sujet du message: Répondre en citant
Hallo Wolfgang
gratuliere zu diesem schönen Vogel, hoffen wir, dass die Wasserkuppe auch das entsprechende Wetter für uns bereit hält [peur] .
Bis bald.
Page 2 sur 3
