Posté le: 11/12/2011 09:28 Sujet du message: |
Nice effect made by the sunlight through the translucent covering material |
Olli Incurable Posteur
Posté le: 11/12/2011 11:25 Sujet du message: |
Vincent ??? |
michelwi Stagiaire Posteur
Posté le: 09/01/2017 13:16 Sujet du message: |
Hi Chris,
Beautifull and well streamed model.
Is it possible to install an electric motor in your Topaze 1:3,5?
Thanks for your answer.
Kind regards,
Michel |
cw Accro Posteur
Posté le: 09/01/2017 13:37 Sujet du message: |
Yes, it is perfectly possible, Michel, as the construction of the Zug and the Topaze are almost identical...
cw |
Posté le: 09/01/2017 14:07 Sujet du message: |
Thanks Chris for your really faster answer.
If the Zugvogel is avalaible in kit, I will have to make a choice.
Other way I will probably order the topaze.
First i have to make some free space on my workplace.
regards,
Michel |
ValerioA Apprenti Posteur
Posté le: 09/01/2017 17:13 Sujet du message: |
Questo è il mio Topaze con motore Brushless 650Kv, 900W, elica13*8, 4 LiPo 4200Mah
Valerio
Posté le: 09/01/2017 19:13 Sujet du message: |
grazie mille Valero
this is exactly what I need to know
ciao,
Michel |
Posté le: 10/01/2017 18:44 Sujet du message: |
Valerio |
