Jigé 200 (1943) Build
czirh
Âge: 63 Sagittaire
MessagePosté le: 09/01/2012 12:16    Sujet du message: Répondre en citant
Building of the nose cone. Epoxi + glass fabric
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 09/01/2012 20:06    Sujet du message: Répondre en citant
What kind of coating and technique should I use to make it fully look like an oldtimer. Any recmomendations or link would be appreciated.
Thank you..
Cem Zırh
Fafnir
MessagePosté le: 09/01/2012 20:13    Sujet du message: Répondre en citant
Why not silk, or polyester paper
http://www.retroplane.net/forum/viewtopic.php?t=3149&postdays=0&postorder=asc&start=105
to order this paper http://www.retroplane.net/forum/viewtopic.php?p=87502#87502
Âge: 50 Capricorne
MessagePosté le: 09/01/2012 21:07    Sujet du message: Répondre en citant
Very Happy Good choise if you want something strong ,light and easy .It fixed like classic paper white dope .
czirh
Âge: 63 Sagittaire
MessagePosté le: 10/01/2012 11:17    Sujet du message: Répondre en citant
Can I manage it I do not know? I have not tried so far. [humm]
Cem Zırh
Fafnir
MessagePosté le: 10/01/2012 11:22    Sujet du message: Répondre en citant
With Silk? in french "soie" look here http://www.retroplane.net/forum/viewtopic.php?t=483&postdays=0&postorder=asc&start=15
czirh
Âge: 63 Sagittaire
MessagePosté le: 12/01/2012 09:19    Sujet du message: Répondre en citant
fotos last fuselage
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 12/01/2012 17:47    Sujet du message: Répondre en citant
Rudder construction. Photos are before surfacing and sanding.
Cem Zırh
Fafnir
MessagePosté le: 12/01/2012 18:52    Sujet du message: Répondre en citant
Nice work and original subject [clap]
czirh
Âge: 63 Sagittaire
MessagePosté le: 14/01/2012 10:17    Sujet du message: Répondre en citant
Thank you, Hecquetmarc.. Very Happy
Tail will be very heavy, so it appears I will have to add significant weight to the nose. Making it EP seems to be a better idea. [humm]
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 14/01/2012 15:56    Sujet du message: Répondre en citant
Elevator construction. Photos are before surfacing and sanding.
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 15/01/2012 11:11    Sujet du message: Répondre en citant
Tail for Jigé 200.. Rolling Eyes
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 16/01/2012 16:33    Sujet du message: Répondre en citant
Construction of the engine hood..
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 23/01/2012 16:08    Sujet du message: Répondre en citant
New photos of the fuselage.
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 23/01/2012 18:15    Sujet du message: Répondre en citant
Main spars and joiners.
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 25/01/2012 15:04    Sujet du message: Répondre en citant
I started the wings construction.
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
MessagePosté le: 26/01/2012 07:20    Sujet du message: Répondre en citant
What is written here?
Merci.
Cem Zırh
Fafnir
MessagePosté le: 26/01/2012 07:27    Sujet du message: Répondre en citant
MA ? but why? maybe someone know?
raduga
Âge: 67 Taureau
MessagePosté le: 26/01/2012 07:44    Sujet du message: Répondre en citant
trés probablement M.A. sur une aile et C.P sur l'autre, soit M.A.C.P:
MODELE AIR CLUB DE PARIS
czirh
Âge: 63 Sagittaire
MessagePosté le: 26/01/2012 17:07    Sujet du message: Répondre en citant
Thank you, Michel.. [good]
Cem Zırh
Fafnir
outremanchot
Âge: 87 Vierge
MessagePosté le: 26/01/2012 21:38    Sujet du message: Répondre en citant
Hi Cem,
For your "M.A." question, Michel is certainly right.
If JG could see your model and the progress you're making, he would be so pleased I'm sure.
Great job!
Brian
czirh
Âge: 63 Sagittaire
Nouveau messagePosté le: 29/01/2012 17:10    Sujet du message: Répondre en citant
Thank you, Brian. Very Happy
I placed the pieces together to see what it looks like and to take pictures.
[humm] And running in for 0.30 ASP.
Cem Zırh
Fafnir
Nouveau messagePosté le: 29/01/2012 17:15    Sujet du message: Répondre en citant
What funny look [good] I love it
Âge: 80 Balance
Nouveau messagePosté le: 30/01/2012 21:33    Sujet du message: Répondre en citant
Superbe !! quelle gueule !!
[clap] [clap] [clap]
czirh
Âge: 63 Sagittaire
Nouveau messagePosté le: 31/01/2012 15:10    Sujet du message: Répondre en citant
Thank you Vincent and Jean-Paul. She is very funny looks.. Laughing
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
Nouveau messagePosté le: 31/01/2012 15:11    Sujet du message: Répondre en citant
wing consolidation
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
Nouveau messagePosté le: 01/02/2012 16:59    Sujet du message: Répondre en citant
Wings + fuselage connection and joiners.
Cem Zırh
Fafnir
czirh
Âge: 63 Sagittaire
Nouveau messagePosté le: 04/02/2012 13:53    Sujet du message: Répondre en citant
Fuselage coating: epoxi + glass fabric
Cem Zırh
Fafnir
Âge: 50 Capricorne
Nouveau messagePosté le: 04/02/2012 15:48    Sujet du message: Répondre en citant
Shocked, why you don't use paper and dope ? Your airfields are verry bad ?
Nouveau messagePosté le: 04/02/2012 15:54    Sujet du message: Répondre en citant
Nice construction. Classic covering would have been better choice ? [humm]
Page 2 sur 4
