awiatik Stagiaire Posteur
Posté le: 16/04/2012 15:58 Sujet du message: IKAR Polish glider of 1925. |
Hi all,
Somehow I have long bore me to build a glider Polish pre-war structures, namely the pioneer period.
The scale is 1/10, is becoming quite popular in the west.
A little history:
This glider designers were Jan Kazimierz Czarnecki and Vronsky.
The glider was built in the carpentry shop in Poznan railway workshops. The glider was planned to complete before the Second Competition Glider, but unfortunately failed to finish work on time.
In the spring of 1926 years of glider made a few jumps. Later dorobiono glider landing gear wheel to try to take off the car, but such attempts were not authorized. Some time later, he was corrupted and deleted.
span - 10 m
Length - 6 m
height - 1.7 m
wing area - 17 m2
excellence around 10
So much for historical trait.
design process using the "latest" technology.
Time to get on with the construction: the hull and cut templates leaf profile
strengthen the sides of the slats balsowych 3x3 mm. |
Posté le: 16/04/2012 18:15 Sujet du message: |
Hi "awiatik" welcome to the forum if you can give us your firstname
I love these originals gliders, glad to follow your building
Posté le: 16/04/2012 18:18 Sujet du message: |
Construction continued:
next step: wings...
...vertical tail
Initial submission of the whole model
covering japan tissue,
painting fusellage,
RC equipment:
Model flight very nicely, and I regret that there is a larger scale.
But the next model glider will be on a larger scale. |
Posté le: 16/04/2012 18:24 Sujet du message: |
« VincentB » a écrit: Hi "awiatik" welcome to the forum if you can give us your firstname
Hi Vincent,
My name is Konstanty in short Kostek
Model builds on 30 years. |
Posté le: 17/04/2012 11:35 Sujet du message: |
Hi Kostek
What is the final weight? the flight is on the slope or at a field?
Posté le: 17/04/2012 13:13 Sujet du message: |
The total weight 239 grams for the flight. Trial flights I took on a little slope, then flying through the hall.
Regards
Kostek |
