Grüne Post
Adler
MessagePosté le: 06/01/2015 15:30    Sujet du message: Grüne Post Répondre en citant
Hello,
I started the construction of a German glider Grüne Post. The model is from the kit Hexe Model. I have done partly fuselage. Construction of a model is pleasant and goes quickly.
Petr
Very Happy
Adler
MessagePosté le: 15/01/2015 12:52    Sujet du message: Re: Grüne Post Répondre en citant
Greetings,
continuing with the construction of a German glider Grüne Post. I work on the fuselage of the glider.
The cover is 0.6 mm plywood. Very Happy
Adler
MessagePosté le: 23/01/2015 14:41    Sujet du message: Re: Grüne Post Répondre en citant
Hello,
I also made some progress in construction. I finished rudder. I shaded it before coating. Little did I suggested interior.
Petr
Very Happy
Tatodesign
Âge: 63 Capricorne
MessagePosté le: 02/02/2015 10:05    Sujet du message: Répondre en citant
Hi Petr,
congratulations, neat work!
I will follow you with interest, I have too the HEXE short kit
and I will start it as soon as I finish the painting of a big ME 262 for a friend
Adler
MessagePosté le: 03/02/2015 08:53    Sujet du message: Répondre en citant
Hello,
Thank you. Construction of a model is quick and easy. You will be satisfied. In two days I have almost finished wings. I will now be coated plywood 0.6.
Petr Very Happy
Adler
MessagePosté le: 05/04/2015 18:26    Sujet du message: Re: Grüne Post Répondre en citant
Greetings
I continue building Grüne. I finished fuselage. The cover will be Solartex.
Fuselage, I modified a bit.
Petr
Very Happy
MessagePosté le: 06/04/2015 09:57    Sujet du message: Répondre en citant
[clap] [clap] [clap] [clap]
RichardP
Âge: 77 Cancer
MessagePosté le: 06/04/2015 10:52    Sujet du message: Répondre en citant
[good] [clap] nice building
Adler
MessagePosté le: 04/06/2015 20:15    Sujet du message: Re: Grüne Post Répondre en citant
Hallo,
Today we are in our at the airport for the first time flying the new gliders. Grüne Post and Krajánek. Everything managed to. Two towing flying constantly. Nice weather.
Here are the photos.
http://rcmpilot.rajce.idnes.cz/Aerovleky_4.6.2015/
Petr
Very Happy
MessagePosté le: 04/06/2015 21:06    Sujet du message: Répondre en citant
H Petr,
die Holzoberfläche sieht super aus [clap] [clap]
Erix
MessagePosté le: 05/06/2015 09:55    Sujet du message: Répondre en citant
Ahoj Petře,
Krásné probarvení, vyniká konstrukce. No je poznat PAN maketář. Ať ti slouží.
P.S. Ta dvouocasá/dvousměrovková vlečná je móóóóc hezká. Kdo je prosím majitel/stavitel.
Erix
Adler
MessagePosté le: 06/06/2015 16:23    Sujet du message: Répondre en citant
Ahoj Eriku,
poslal jsem Ti mail. Děkuji,snažil jsem se. Líbí se mi ta velikost.Třímetrovka,celkově robustní ale skladné do auta.
Petr Very Happy
CHAUSSEBOURG
Âge: 88 Taureau
MessagePosté le: 06/06/2015 17:53    Sujet du message: Répondre en citant
Very good pictures [clap] [clap] [clap] . The Zlin 24 does not look very different from my Castel 3010.
LDC
LV
Âge: 60 Bélier
MessagePosté le: 06/06/2015 18:01    Sujet du message: Re: Grüne Post Répondre en citant
« Adler » a écrit:
Hallo,
Petr
Very Happy
Petře gratuľujem k záletu krásne spracovaného vetroňa. [clap] [clap] [clap]
Laco
Tatodesign
Âge: 63 Capricorne
MessagePosté le: 18/06/2015 11:15    Sujet du message: Répondre en citant
« Adler » a écrit:
Hello,
Petr Very Happy
Hallo Adler,
I had to start works on the same model.
Could you let me to see how did you curved the plywood on leading edge?
Thank you and congratulations [amen]
Stefano
Adler
MessagePosté le: 18/06/2015 17:41    Sujet du message: Répondre en citant
Hello Stefano,
On covering of the wing I used balsa. The wings are colored. I gliders fuselage covered with plywood.
Petr
Very Happy
Nouveau messagePosté le: 18/06/2015 19:01    Sujet du message: Répondre en citant
Sehr schön geworden Petr [clap] [clap]
Ich wünsche Deiner Post und Dir immer gute Flüge und noch bessere Landungen [vol]
Tatodesign
Âge: 63 Capricorne
Nouveau messagePosté le: 22/06/2015 15:50    Sujet du message: Répondre en citant
« Adler » a écrit:
Hello Stefano,
Petr
Very Happy...
Good idea!
Really a nice work, congratulations! We will see it and meet you at Wasserkuppe?
best regards
Stefano
Adler
Nouveau messagePosté le: 22/06/2015 18:50    Sujet du message: Répondre en citant
Hi Stefano,
Thank you. On Wasserkuppe unfortunately I will not. I missed to log on time.
I have a nice flying, and weather.
Very Happy Wink
Petr
carlominimoa
Âge: 61 Bélier
Nouveau messagePosté le: 23/06/2015 14:27    Sujet du message: Répondre en citant
Hello, I'm just approaching the wings and I don't understand the first three root ribs how they do the dihedral...is there any diehedral in this model?
Because from the three view I don't see any!! Shocked Shocked
Please Help me to understand also with some photos.
Tnx
Carlo
Adler
Nouveau messagePosté le: 24/06/2015 08:47    Sujet du message: Répondre en citant
HELLO,
I dihedral wings by kits. It's a bit more than it should be. The model is more stable in flight. The wings are fiberglass rods. Dihedral is made in root ribs
http://www.hexemodel.cz/Grune_Post/Building%20guide%20-%20Grune%20Post%20-%20wing.pdf
Petr Very Happy
RichardP
Âge: 77 Cancer
Nouveau messagePosté le: 24/06/2015 14:27    Sujet du message: Répondre en citant
EXCELLENT !!! [good] [good] [good]
