CVV - 4 Pellicano
RobertoP
Âge: 61 Balance
MessagePosté le: 03/12/2011 22:18    Sujet du message: CVV - 4 Pellicano Répondre en citant
Hi All,
after having concluded my Bocian, I start the design of a new glider, the CVV 4 Pellicano an Italian 15m sailplane. I decide for ¼ scale, my design follow the construction method used by Vincent for MG9, I would like to try all plywood construction. Now I have concluded the drawing of fuselage, and also the project of the wing is quite at the end. Here my fuselage project and some photo of full scale glider.
Roberto
MessagePosté le: 04/12/2011 07:09    Sujet du message: Répondre en citant
Hi Roberto, it's a nice winter's project Very Happy
Âge: 52 Gémeau
MessagePosté le: 04/12/2011 22:19    Sujet du message: Répondre en citant
Hi Roberto,
yes, it's a magnificent glider, i like it very much Very Happy
Good luck for building it Wink
ValerioA
Âge: 70 Capricorne
MessagePosté le: 05/12/2011 11:09    Sujet du message: Répondre en citant
Ciao Roberto,
ma per avere notizie sul Pellicano devo consultare Retroplane???? Rolling Eyes
Valerio
MessagePosté le: 05/12/2011 19:54    Sujet du message: Répondre en citant
[good] Wink
MessagePosté le: 05/12/2011 23:03    Sujet du message: Répondre en citant
Rather similar to the Minimoa Wink nice project
RobertoP
Âge: 61 Balance
MessagePosté le: 08/01/2012 00:31    Sujet du message: Répondre en citant
Hi All
I have concluded the drawing of the wings now I need to start with the cutting of various pieces and start the construction
Very Happy .
Roberto
RobertoP
Âge: 61 Balance
MessagePosté le: 25/03/2012 22:59    Sujet du message: Répondre en citant
Hi All,
the construction of my Pellicano is started, first I make an order to easy CNC for cuttings the ribs, than I cut the various pieces of fuselage and start the work for the stabilizer that now is concluded. The next step is the fuselage.
Roberto
MessagePosté le: 26/03/2012 07:10    Sujet du message: Répondre en citant
Nice work for the stabilizer [clap]
RobertoP
Âge: 61 Balance
MessagePosté le: 01/04/2012 18:49    Sujet du message: Répondre en citant
Hi All,
Today I start with the construction of fuselage with the first dry test
Roberto
RobertoP
Âge: 61 Balance
MessagePosté le: 15/04/2012 20:46    Sujet du message: Répondre en citant
Hi,
The structure of fuselage is quite finish now I have to start with cockpit and the control system of horizontal tail and then the covering with plywood.
The photo on the book is the photo of full scale Pellicano on construction.
Roberto
MessagePosté le: 15/04/2012 21:14    Sujet du message: Répondre en citant
[clap] [clap] [clap] [clap]
RobertoP
Âge: 61 Balance
MessagePosté le: 30/04/2012 20:48    Sujet du message: Répondre en citant
Thanks Christian,
the work on Pellicano is proceeding slowly,now I start with the sheeting of fuselage here enclosed some photos.
Roberto
MessagePosté le: 01/05/2012 05:53    Sujet du message: Répondre en citant
Hi Roberto, great work [clap] plywood is really the best Very Happy
ValerioA
Âge: 70 Capricorne
MessagePosté le: 02/05/2012 09:28    Sujet du message: Répondre en citant
Bravo Roberto, super work! [clap] [clap]
valerio
RobertoP
Âge: 61 Balance
MessagePosté le: 06/05/2012 21:21    Sujet du message: Répondre en citant
Hi All,
Following the sheeting of the full scale Pellicano the covering of fuselage is proceeding
Roberto
Roberto
RobertoP
Âge: 61 Balance
MessagePosté le: 07/05/2012 23:16    Sujet du message: Répondre en citant
Hi,
other photos
roberto
RobertoP
Âge: 61 Balance
MessagePosté le: 23/09/2012 18:17    Sujet du message: Répondre en citant
Hi All,
Some photos of fuselage of my Pellicano covered, with plywood.
Roberto
MessagePosté le: 23/09/2012 18:53    Sujet du message: Répondre en citant
Hi Roberto,
Very beautiful work on the plywood [clap]
RobertoP
Âge: 61 Balance
MessagePosté le: 30/09/2012 21:08    Sujet du message: Répondre en citant
Hi Vincent,
thanks, but unfortunately my work is not so good as your work on your Musger MG9, you are so precise in the junction of various plywood panels and I really I do not understand how you can do this perfect junction.
Here enclosed other two photos of my Pellicano
Roberto
MessagePosté le: 01/10/2012 06:08    Sujet du message: Répondre en citant
No problem, that's realistic like this, full size had same look
MessagePosté le: 02/10/2012 10:06    Sujet du message: Répondre en citant
very Nice work Roberto, you can obtain better junctions of the panels with cutting templates prior to the cutting of the panels themselves to fit them perfectly but not too much ( it's a long work but no waste of plywood and more precise work) .
Avoid to sand too much the junction of the panels. It is worth bevelling carefully the panels and then you can determine the gap between them and there's almost no need to sand .
[clap]
RobertoP
Âge: 61 Balance
MessagePosté le: 20/10/2012 20:59    Sujet du message: Répondre en citant
Hi All ,
Now I have concluded the covering of fuselage of my Pellicano and now I am working on karman here enclose some photos
Roberto
MessagePosté le: 21/10/2012 09:42    Sujet du message: Répondre en citant
[clap] [clap] [clap] [baaave]
Hibernatus
Âge: 67 Poissons
MessagePosté le: 27/10/2012 23:40    Sujet du message: Répondre en citant
Jolie construction [clap] [clap]
Les plans de joints sont très réalistes [good2]
@++ Christian
RobertoP
Âge: 61 Balance
MessagePosté le: 28/10/2012 19:42    Sujet du message: Répondre en citant
Hi All,
many thanks to all for the compliments, today I have concluded the covering of fuselage now I have to start with the moving part of rudder and then the wings .
Roberto
RobertoP
Âge: 61 Balance
MessagePosté le: 01/01/2013 17:38    Sujet du message: Répondre en citant
Hi All ,
I would like to wish to all peoples of the forum an happy new 2013, speaking about my Pellicano I have concluded the rudder and I start with the wings here some photos
Roberto
RobertoP
Âge: 61 Balance
MessagePosté le: 13/01/2013 21:51    Sujet du message: Répondre en citant
Hi All,
other pictures of my Pellicano,
Roberto
MessagePosté le: 14/01/2013 09:46    Sujet du message: Répondre en citant
Salut Roberto !
[amen] [amen]
MessagePosté le: 14/01/2013 11:58    Sujet du message: Répondre en citant
[clap] [clap] Very nice building Roberto...Happy new year to you and your family.
" Ah, ces ailes en mouette.."
" Ah, these gull winged sailplanes.. ( famous sentence on Retroplane forum ) Wink
