Ka3 to Italy
gianfry2866
MessagePosté le: 12/07/2007 15:55    Sujet du message: Répondre en citant
how to have this plans in italy????
MessagePosté le: 12/07/2007 16:40    Sujet du message: Répondre en citant
Good evening first ! [humm] Here it's like a family place thank you...
MessagePosté le: 12/07/2007 16:48    Sujet du message: Répondre en citant
Hi Gianfry
Contact LoopingFred! He sell plan or short kit of his KA3!
Enjoy
gianfry2866
MessagePosté le: 12/07/2007 17:14    Sujet du message: Répondre en citant
tks at everyones
i'll tried to contact via e-mail and mp several times...
but no answer i recived.......
i will try again ...tks
MessagePosté le: 12/07/2007 17:34    Sujet du message: Répondre en citant
« gianfry2866 » a écrit:
tks at everyones
He is traveling at the moment, so be patient, he will answer Very Happy
gianfry2866
MessagePosté le: 12/07/2007 17:36    Sujet du message: Répondre en citant
tks a lot stephan....
Nouveau messagePosté le: 12/07/2007 17:42    Sujet du message: Répondre en citant
Hi gianfry
I in order not to interrupt the thread of Erwan, I will create a new one with the name "Ka3 for Italy" and move everything in there. Please use this one for any future entries concerning your Ka3 demand. You can also show us than the advancement of your constrcution, ok Very Happy
member of the moderation team
gianfry2866
Nouveau messagePosté le: 12/07/2007 19:55    Sujet du message: Répondre en citant
MANY TKS.....
loopingfred
Âge: 50 Gémeau
Nouveau messagePosté le: 12/07/2007 20:36    Sujet du message: Répondre en citant
after 48hrs of travel, I'm back home ! Need to rest now !
Gianfry, I have all your mails and PM, i'll answer all of them asap.
MORE BEERS!!!!
gianfry2866
Nouveau messagePosté le: 03/07/2008 16:02    Sujet du message: Répondre en citant
after one year and my first son...i decided to start build the ka3.....
now the first problem.....
on the short kit by Fred all the ribs are precutted for a longherons pin of 17x7......but it's impossible to find at any brico this kind of mesure...
someone may suggest how to solve this problem....i don't wont cut new ribs for a different longherons....
the only mesure i have found is oyus 15x5..........
tks a lot
loopingfred
Âge: 50 Gémeau
Nouveau messagePosté le: 03/07/2008 16:21    Sujet du message: Répondre en citant
Hi Gianfry,
Glad you finaly going to start the Ka3 ! Very Happy
For the 17x7, I don't really have a solution...
Maybe glue a 2mm balsa strip on 2 sides on the 15x5 pine you have found [humm]
I did that once for one of my glider, and worked fine...
Other than that, you will have to cut your own spar Confused
Another thing while we are at it, because you have an old kit, can you measure the lenght of the ribs compared to the plan ?
If you find any differences, can you send me your address by PM ? and I'll will send you a new set of ribs (but still with a 17x7mm spar I'm affraid...). I don't recall I have contacted you regarding this issue [humm]
Fred
MORE BEERS!!!!
gianfry2866
Nouveau messagePosté le: 03/07/2008 17:18    Sujet du message: Répondre en citant
ok fred i will compare the ribs with the plans ....ana i will let u know
