A new Harbinger in Spain
Poster un nouveau sujet   Répondre au sujet    RETROPLANE.net Index du Forum -> HARBINGER
Daniel
MessagePosté le: 26/10/2007 17:41    Sujet du message: A new Harbinger in Spain Répondre en citant
Dear all,
First of all sorry for not speaking French...
Well, the subjet says it all, I'm starting to build a Harbinger. It will take a time, since I do not have too many free time, but I'll finish it some day. I'm in love of this plane.
For the moment I have already cutted out the fuselage formers and the first doubt arrived: on the building manual it is said that the front part of the fuse must be built upside down, over a 15mm template that simulates the cockpit surface... well, is there any template of that piece? on the plan I cannot find it.
Any clue will be highly appreciate.
Thanks in advance,
Daniel
PD1 It's my first builders project since all my previous models were kit. It's a bit scaring for me.
PD2 I'll be posting my advances from time to time.
PD 3 Alonso,pls return to Renault !!
MessagePosté le: 26/10/2007 18:18    Sujet du message: Répondre en citant
Hello Daniel, welcome on the forum Very Happy
it's not on the plan, because it's easy to draw it
enclosed the dxf file, if you prefere a pdf file to print, I can make it
chantier.zip
 Nom du fichier:  chantier.zip
 Taille du fichier:  75.25 Ko
 Téléchargé:  2498 fois
Daniel
MessagePosté le: 26/10/2007 18:24    Sujet du message: Répondre en citant
Thanks Vincent, it is very clear. No need .pdf. I'll be posting some pictures as soon as I start glueing.
Daniel
Texier Serge
Âge: 75 Lion
MessagePosté le: 26/10/2007 21:28    Sujet du message: Répondre en citant
Welcome, Daniel,
Don't be sorry for the language, your english is perfect. Very Happy
Daniel
MessagePosté le: 03/11/2007 20:33    Sujet du message: Répondre en citant
Thanks Serge.
Well, I was about to start glueing today but I have discovered that some of the fuselage formers are a lttle bit twisted Shocked ...so when putting all together on the "quille" they are not straight. Any hint to make them flat again? Maybe with water and some heavy charge over them until they get dry? I never face this problem before....
Thanks in advance
Daniel
MessagePosté le: 03/11/2007 20:54    Sujet du message: Répondre en citant
The "quille" must be straight on the table, but let the formers twisted, you can't rectify them... verify and align the formers when you will glueing the spars
sorry my english is very poor Embarassed
Daniel
MessagePosté le: 03/11/2007 21:44    Sujet du message: Répondre en citant
Ok Vincent, clear. The quille is straight. I'll correct the formers on the way...
Seems that you are always on duty, aren't you? You always reply very fast (thanks God).
Thanks,
Daniel
Your English is quite good (better than my French Sad )
MessagePosté le: 04/11/2007 07:56    Sujet du message: Répondre en citant
no no I don't answer 21h to 6h morning Laughing
Daniel
MessagePosté le: 04/11/2007 20:37    Sujet du message: Répondre en citant
I have been working for a while this afternoon. here you have the first picture (sorry it's not very good, it was taken with my mobile phone)
Good nigth to all
Daniel
gustavomg9
MessagePosté le: 05/11/2007 13:34    Sujet du message: Répondre en citant
Que tal daniel que lindo modelo ya somos mas los hispano parlantes un abrazo de parte de gus.
desde el fin del mundo (argentina)
Voir le profil de l'utilisateur Envoyer un message privé Envoyer un e-mail Yahoo Messenger
Daniel
MessagePosté le: 05/11/2007 13:47    Sujet du message: Répondre en citant
Saludos, Gustavo. Yo también me alegro....
No te animas a construirlo?
gustavomg9
MessagePosté le: 05/11/2007 14:35    Sujet du message: Répondre en citant
Lo que pasa dany es que estoy construyendo a la misma vez un mg9
un k3 y un doopy y el ala szd 6 nietorpetz aparte de construir los modelos en los que compito en mi pais
aparte ser padre esposo dormir comer jugar con mi nena no me queda tiempo para este modelo lo que no significa que no tenga el plano de ese y unos cuantos modelos mas del foro que te parece un abrazo gus
Daniel
MessagePosté le: 05/11/2007 15:16    Sujet du message: Répondre en citant
Me mareo de pensarlo, no sé cómo puedes con todo. Yo he empezado a hacérmelo, pero no sé cuanto tardaré, también tengo dos hijos....
Daniel
MessagePosté le: 05/11/2007 15:41    Sujet du message: Répondre en citant
Sorry, no more chatting in Spanish.... Embarassed
gustavomg9
MessagePosté le: 05/11/2007 15:46    Sujet du message: Répondre en citant
dany fijate en el foro en la parte de" vuestros proyectos" ( escrito en frances)y vas a ver mis modeos el ala y el mg9 saludos gus
Daniel
MessagePosté le: 05/11/2007 16:32    Sujet du message: Répondre en citant
Muy bonitos....
TorresM
Âge: 84 Capricorne
MessagePosté le: 06/11/2007 11:16    Sujet du message: Hola Daniel Répondre en citant
Bienvenido al foro. Estoy a tu disposición, si en álgo te puedo servir...
Bons Vols...
Manolo
MessagePosté le: 06/11/2007 11:22    Sujet du message: Répondre en citant
Hi guys
nobody than you can follow this discussion in the forum. It would be nice if you could change to a language which at least the majority of the members could understand [arf] (german for example MDR)
Daniel
MessagePosté le: 06/11/2007 11:50    Sujet du message: Répondre en citant
Hi Stephan,
Yes I agree with you. If you read my yesterday's post I asked not to speak Spanish here (even if I whish) or a different languaje than French/English, because I think that evertybody must understand what it is being discussed....
We can always send PM.
Thanks a lot Manolo !!
Daniel
Daniel
MessagePosté le: 06/11/2007 20:46    Sujet du message: Répondre en citant
Here you have my today's progress.... do not think I'm going to take pictures of every single piece of wood cutted, it is just because it seems that we are loosing the thread of this post Very Happy
As I advise you at the beginning, it is going to be a very slooooow building, because.
1.I do not have a CNC machine, so I have to cut all the pieces by hand.
2.Not too much time to build.
3.Two kids at home.
But do not worry I think I'll be maiden it on Retroplane 2015 Laughing
MessagePosté le: 06/11/2007 20:54    Sujet du message: Répondre en citant
Daniel
Don't worry, it is not a race Wink Everybody makes on his speed, time after time with pleasure of course Wink
I find you go ahead with a good rate even you do all thinks with your hands! So, so Wink
TorresM
Âge: 84 Capricorne
MessagePosté le: 06/11/2007 21:00    Sujet du message: perdon Répondre en citant
Bien. Je seul donnais la bienvenue au forum à un nouveau membre.
Stephan, j'entends ton problème. Il est le même que j'ai devant les écrits chez l'Allemand.
Perdon, S.V.P.
Bons Vols...
Manolo
Daniel
MessagePosté le: 07/11/2007 11:08    Sujet du message: Répondre en citant
Bon Jour
I'm planning to finish cutting all the formers of the rear part of the fuselage (if I'm lucky), as well as the quille.
But I have one question:
On the formers there is a part on bottom that must be removed (is for allignment) after the fuselage is finished (and before covering it), and I think it must be pre cutted in some way because if not, it will be difficult after all is glued. See attached sketch
Am I right? Or do you have any other suggestion?
Thanks in advance
Daniel
PS Stephan/Manolo, let's calm down....we all have good willing but sometimes is unavoidable to turn to your own languaje Wink
MessagePosté le: 07/11/2007 12:19    Sujet du message: Répondre en citant
« Daniel » a écrit:
...On the formers there is a part on bottom that must be removed (is for allignment)...
exactly as you said, it's for allignement and has to be removed
it is better to cover what ever is possible to cover before cutting them, thus you can avoid any distortion
« Daniel » a écrit:
...and I think it must be pre cutted in some way because if not, it will be difficult after all is glued.
...yes, the formers from Vincent have a slight pre cut, thus no problem for the final cut
Daniel
MessagePosté le: 07/11/2007 12:32    Sujet du message: Répondre en citant
Danke Stephan Very Happy
MessagePosté le: 07/11/2007 12:54    Sujet du message: Répondre en citant
con mucho gusto! [humm] Laughing
Poster un nouveau sujet   Répondre au sujet    RETROPLANE.net Index du Forum -> HARBINGER Toutes les heures sont au format GMT + 2 Heures
