cw Accro Posteur
Posté le: 21/08/2009 07:35 Sujet du message: |
It is aluminium Tibor...
 cw |
cw Accro Posteur
Posté le: 25/08/2009 23:27 Sujet du message: |
Moving to the front now, it is time to look at the cockpit...
The frames are laminated from strips of .75mm CTP
A tempate is used to trim the frame to the correct height...
 cw |
cw Accro Posteur
Posté le: 28/08/2009 21:07 Sujet du message: |
Before I can go any further, I must make up the tool to form the canopy...
Blue foam plates make up the bulk of the former
Now the foam is covered with brown parcel tape...
Then, two layers of chopped mat fibreglass with polyester resin
The whole thing is then filled and sanded down...
 cw |
Chris Ze Swiss Accro Posteur
Posté le: 28/08/2009 22:47 Sujet du message: |
Hello Chris,
Only one smiley : ... as everytime !
à +, Chris
cw Accro Posteur
Posté le: 31/08/2009 22:21 Sujet du message: |
The canopy former is ready to go to the vacform company, so now it's back to the canopy frames...
The joints are reinforced with 1mm piano wire
 cw |
Posté le: 31/08/2009 22:31 Sujet du message: |
Hi Chris ,
I follow youir building closely, as useal quick and great, but one question!
I do not understand why ?, you put some tape on the canopy former , before the the fiber glass?
On my Fauvel I did the same method , but without!
cw Accro Posteur
Posté le: 31/08/2009 22:55 Sujet du message: |
It is just a precaution Pat, to prevent the polyester resin from attacking the blue foam... (It might not be a problem with epoxy resin)
 cw |
cw Accro Posteur
Posté le: 03/09/2009 22:23 Sujet du message: |
With the fuselage and tailplane now complete it is time to build the wings.
There will be a pause while I sharpen my pencils...
 cw |
cw Accro Posteur
Posté le: 07/09/2009 17:42 Sujet du message: |
First, the wing joiner box is made up for the wings...
 cw |
tibor kertesz Stagiaire Posteur
Posté le: 07/09/2009 21:28 Sujet du message: wood |
| chris, what kind of wood are you using for the main spar of the wing? |
cw Accro Posteur
Posté le: 07/09/2009 21:57 Sujet du message: |
Tibor, it is 12 x 6mm Spruce, parallel on the first panel and tapering to 6 x5mm at the tip...
 cw |
cw Accro Posteur
Posté le: 08/09/2009 21:46 Sujet du message: |
Now the inner wing panels are built up...
 cw |
cw Accro Posteur
Posté le: 10/09/2009 21:13 Sujet du message: |
Time for a quick look-see...
Now for the outer panels...
 cw |
caralp_laurent Psycho Posteur
Posté le: 11/09/2009 08:35 Sujet du message: |
Hi Chris,
Great, magnificent and built so fast as usually.
Lolométéo
Sénèque |
plu ronan Incurable Posteur
Posté le: 11/09/2009 17:42 Sujet du message: |
good job  |
cw Accro Posteur
Posté le: 11/09/2009 20:59 Sujet du message: |
Merci messieurs... There will be a short pause as we have a big aerotow this weekend. Work will resume next week.
Meanwhile...
 cw |
cw Accro Posteur
Posté le: 16/09/2009 21:42 Sujet du message: |
It is a big job setting up the wings to the fuselage.
The wing spar must be at 90 degrees to the fuselage
Then the wing root fairing must be built up
Now the second wing must be aligned with the first
 cw |
cw Accro Posteur
Posté le: 19/09/2009 00:34 Sujet du message: |
With the wing root fairings completed, the Flamingo's elegance is starting to show...!
Now it is time to finish the wings...
 cw |
cw Accro Posteur
Posté le: 26/09/2009 09:18 Sujet du message: |
I have decided to try something different in the construction of the ailerons... The aileron shrouds on the wing are made from 1.5mm balsa laminated with 0.75 CTP, with the CTP on the outside. Now, the aileron leading edge is made from a lamination of two lengths of 6mm balsa. The LE is now offered up to the wing for the hinge pilot holes...
Cut-outs and balsa reinforcements for the Robart hinges...
The LE is sanded to a round-edged profile and hinged to the wing...
Wing profile templates are used to set up the aileron ribs...
The aileron TE is made from 2.4mm Spruce and 6mm balsa
 cw |
cw Accro Posteur
Posté le: 26/09/2009 19:26 Sujet du message: |
With the TE set up, it is time to add the ribs
Here's my secret...Santa's Little Helper...
 Here, you can see the shrouds covering the aileron
Now the ailerons are complete
 cw |
ultralajt Fidèle Posteur
Posté le: 26/09/2009 19:32 Sujet du message: |
Nice build!
I check often this thread!
Mitja
 Never try, never fail.... |
Posté le: 26/09/2009 21:38 Sujet du message: |
Very interesting lessons of process of building .
Thank you Chris
cw Accro Posteur
Posté le: 26/09/2009 23:06 Sujet du message: |
Merci messieurs, and now...I just had to photograph the complete airframe...!
 cw |
Posté le: 27/09/2009 07:17 Sujet du message: |
It is beauty now already!!! (I mean, the model, not the guy holding it )
I already imagine it in the air.....it will be awesome!
We must admit, that styling of the sailplanes was way ahead of all other vehicles in those days.
Mitja
Posté le: 27/09/2009 09:45 Sujet du message: |
Very beautiful model,
It's another model than dream to pilote it...
Sorry Chris my english it's very poor
czirh Accro Posteur
Posté le: 30/09/2009 21:10 Sujet du message: |
Absolutely nice building , congratulation.. ![[clap]](images/smiles/Clap.gif)
 Cem Zırh
Fafnir |
cw Accro Posteur
Posté le: 10/10/2009 18:32 Sujet du message: |
Just a few details to finish before Solartexing the wings...
 cw |
cw Accro Posteur
Posté le: 11/10/2009 15:03 Sujet du message: |
Time for a quick check of the canopies before painting the wings...
The tail surfaces have aready been lacquered, flatted and lacqered again...
 cw |
Posté le: 11/10/2009 15:41 Sujet du message: |
Wahoo congratulation
Less 3 month you started, you know Lucky Lucke, CW the man who build faster than his shadow |
