HW 4 FLAMINGO 1:3.5 SCALE
1, 2, 3, 4 Suivante
cw
Âge: 77 Sagittaire
MessagePosté le: 21/08/2009 07:35    Sujet du message: Répondre en citant
It is aluminium Tibor...
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 25/08/2009 23:27    Sujet du message: Répondre en citant
Moving to the front now, it is time to look at the cockpit...
The frames are laminated from strips of .75mm CTP
A tempate is used to trim the frame to the correct height...
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 28/08/2009 21:07    Sujet du message: Répondre en citant
Before I can go any further, I must make up the tool to form the canopy...
Blue foam plates make up the bulk of the former
Now the foam is covered with brown parcel tape...
Then, two layers of chopped mat fibreglass with polyester resin
The whole thing is then filled and sanded down...
cw
Chris Ze Swiss
MessagePosté le: 28/08/2009 22:47    Sujet du message: Répondre en citant
Hello Chris,
Only one smiley : [good2] ... as everytime ! Wink
à +, Chris
cw
Âge: 77 Sagittaire
MessagePosté le: 31/08/2009 22:21    Sujet du message: Répondre en citant
The canopy former is ready to go to the vacform company, so now it's back to the canopy frames...
The joints are reinforced with 1mm piano wire
cw
MessagePosté le: 31/08/2009 22:31    Sujet du message: Répondre en citant
Hi Chris ,
I follow youir building closely, as useal quick and great, but one question!
I do not understand why ?, you put some tape on the canopy former , before the the fiber glass? [humm]
On my Fauvel I did the same method , but without! Confused
cw
Âge: 77 Sagittaire
MessagePosté le: 31/08/2009 22:55    Sujet du message: Répondre en citant
It is just a precaution Pat, to prevent the polyester resin from attacking the blue foam... (It might not be a problem with epoxy resin)
cw
MessagePosté le: 01/09/2009 08:12    Sujet du message: Répondre en citant
Hi Chris,
Exactly, only a problem with poleyster Confused
cw
Âge: 77 Sagittaire
MessagePosté le: 03/09/2009 22:23    Sujet du message: Répondre en citant
With the fuselage and tailplane now complete it is time to build the wings.
There will be a pause while I sharpen my pencils... Very Happy
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 07/09/2009 17:42    Sujet du message: Répondre en citant
First, the wing joiner box is made up for the wings...
cw
tibor kertesz
Âge: 33 Cancer
MessagePosté le: 07/09/2009 21:28    Sujet du message: wood Répondre en citant
chris, what kind of wood are you using for the main spar of the wing?
cw
Âge: 77 Sagittaire
MessagePosté le: 07/09/2009 21:57    Sujet du message: Répondre en citant
Tibor, it is 12 x 6mm Spruce, parallel on the first panel and tapering to 6 x5mm at the tip...
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 08/09/2009 21:46    Sujet du message: Répondre en citant
Now the inner wing panels are built up...
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 10/09/2009 21:13    Sujet du message: Répondre en citant
Time for a quick look-see...
Now for the outer panels...
cw
MessagePosté le: 11/09/2009 08:35    Sujet du message: Répondre en citant
Hi Chris, Very Happy
Great, magnificent and built so fast as usually. [amen]
Lolométéo
MessagePosté le: 11/09/2009 17:42    Sujet du message: Répondre en citant
good job Very Happy
cw
Âge: 77 Sagittaire
MessagePosté le: 11/09/2009 20:59    Sujet du message: Répondre en citant
Merci messieurs... There will be a short pause as we have a big aerotow this weekend. Work will resume next week.
Meanwhile...
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 16/09/2009 21:42    Sujet du message: Répondre en citant
It is a big job setting up the wings to the fuselage.
The wing spar must be at 90 degrees to the fuselage
Then the wing root fairing must be built up
Now the second wing must be aligned with the first
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 19/09/2009 00:34    Sujet du message: Répondre en citant
With the wing root fairings completed, the Flamingo's elegance is starting to show...!
Now it is time to finish the wings...
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 26/09/2009 09:18    Sujet du message: Répondre en citant
I have decided to try something different in the construction of the ailerons... The aileron shrouds on the wing are made from 1.5mm balsa laminated with 0.75 CTP, with the CTP on the outside. Now, the aileron leading edge is made from a lamination of two lengths of 6mm balsa. The LE is now offered up to the wing for the hinge pilot holes...
Cut-outs and balsa reinforcements for the Robart hinges...
The LE is sanded to a round-edged profile and hinged to the wing...
Wing profile templates are used to set up the aileron ribs...
The aileron TE is made from 2.4mm Spruce and 6mm balsa
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 26/09/2009 19:26    Sujet du message: Répondre en citant
With the TE set up, it is time to add the ribs
Here's my secret...Santa's Little Helper... Very Happy
Here, you can see the shrouds covering the aileron
Now the ailerons are complete [good2]
cw
ultralajt
Nouveau messagePosté le: 26/09/2009 19:32    Sujet du message: Répondre en citant
Nice build!
I check often this thread!
[clap]
Mitja
Never try, never fail....
Nouveau messagePosté le: 26/09/2009 21:38    Sujet du message: Répondre en citant
Very interesting lessons of process of building Very Happy .
Thank you Chris
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 26/09/2009 23:06    Sujet du message: Répondre en citant
Merci messieurs, and now...I just had to photograph the complete airframe...!
cw
ultralajt
Nouveau messagePosté le: 27/09/2009 07:17    Sujet du message: Répondre en citant
It is beauty now already!!! (I mean, the model, not the guy holding it Wink )
I already imagine it in the air.....it will be awesome!
We must admit, that styling of the sailplanes was way ahead of all other vehicles in those days.
Mitja
Nouveau messagePosté le: 27/09/2009 09:45    Sujet du message: Répondre en citant
Very beautiful model, [baaave]
It's another model than dream to pilote it...
Sorry Chris my english it's very poor
czirh
Âge: 62 Sagittaire
Nouveau messagePosté le: 30/09/2009 21:10    Sujet du message: Répondre en citant
Absolutely nice building , congratulation.. [clap]
Cem Zırh
Fafnir
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 10/10/2009 18:32    Sujet du message: Répondre en citant
Just a few details to finish before Solartexing the wings...
cw
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 11/10/2009 15:03    Sujet du message: Répondre en citant
Time for a quick check of the canopies before painting the wings...
The tail surfaces have aready been lacquered, flatted and lacqered again...
cw
Nouveau messagePosté le: 11/10/2009 15:41    Sujet du message: Répondre en citant
Wahoo congratulation [clap]
Less 3 month you started, you know Lucky Lucke, CW the man who build faster than his shadow
1, 2, 3, 4 Suivante
Page 2 sur 4
