uav-oscar Apprenti Posteur
Posté le: 03/03/2011 20:48 Sujet du message: |
Tesekkurler abi.. |
Posté le: 04/03/2011 05:24 Sujet du message: |
This is the first Doppi in Turkey which build from Cem Zirh and mine will be the second one..
Posté le: 04/03/2011 10:04 Sujet du message: |
Posté le: 04/03/2011 22:45 Sujet du message: |
Thanks Christian... |
Posté le: 04/03/2011 23:01 Sujet du message: |
Tomorrow I will start building the wings..
But tonight I have a problem... I do not know if its dxf mistake or my laser cut machine problem???
Main spar shown 5x10mm on the plan & dxf, but all ribs (balsa & plywoods) have 6x10mm cut for spar..
As a solution I cut tiny pieces from 1mm balsa and glue it every ribs on the wing..
Posté le: 04/03/2011 23:04 Sujet du message: |
I fix this problem but it took long time.. I am ready for wing construction now..
Posté le: 05/03/2011 05:51 Sujet du message: |
I re-checked the dxf is well 10x5mm
Strange indeed that the cuts are at 11mm
There is not a bad parameter cutting, which cuts outside the lines?
Posté le: 05/03/2011 16:42 Sujet du message: |
Some details on wing construction..
I use carbon tubes for wing joiner..
Dihedral...
Posté le: 05/03/2011 16:43 Sujet du message: |
Posté le: 05/03/2011 16:47 Sujet du message: |
My friend Osman abi help me a lot for the wing construcion.. Honestly as I did not build scratch style for long years, I request him to help me..
He is a more then 40 years modeling experience ( especially Free Flight), also he is building http://www.retroplane.net/forum/viewtopic.php?t=3310
Zlin Z-24 ..
Thank you Osman abi.. |
Posté le: 05/03/2011 16:50 Sujet du message: |
Posté le: 05/03/2011 16:52 Sujet du message: |
Now I am waiting for drying time of Aliphatic glue..
Posté le: 05/03/2011 19:02 Sujet du message: |
It's nice to work with friends Good job |
Posté le: 05/03/2011 20:08 Sujet du message: |
Aliphatic glue dry at the end..
Posté le: 05/03/2011 20:10 Sujet du message: |
Now Shear web time..
Posté le: 05/03/2011 21:13 Sujet du message: |
Viva Andino balsa ! Why not Rétroplane in Turkey in the next years ? ...Do you have convenient slope soaring places? |
Jac50 Maniaco Posteur
Posté le: 06/03/2011 09:29 Sujet du message: |
Congratulation,
It's a good job, well and quickly done.
I will follow your construction.
Friendly.
Jacques.
(Jacques Rouxel). |
Posté le: 06/03/2011 09:36 Sujet du message: |
Thank you Jacques...
We are lucky that Vincent have dxf plans of Doppi, which makes us much quicker construction by the help of laser cut.. |
Posté le: 09/03/2011 13:42 Sujet du message: |
So much snow for today and I prefer to stay home
Posté le: 09/03/2011 13:45 Sujet du message: |
Still building left wing..
I could not cut triangles same
Posté le: 09/03/2011 14:15 Sujet du message: |
Ho snow at Ankara, very rare no?
Posté le: 09/03/2011 15:53 Sujet du message: |
For March this much snow is not usual Vincent..
But it gave me a full free day for Doppi construction |
Posté le: 09/03/2011 17:33 Sujet du message: |
Last 17 years , we did not have this much snow ( from tv news )
45 cm. snow on the top of my car
My wife car ( hard to believe but its a WW Golf )
I spend 1.5 hours to plow the snow
Posté le: 09/03/2011 17:57 Sujet du message: |
You're right, it's better to stay in the workshop, good weather for progress in building |
Posté le: 10/03/2011 21:16 Sujet du message: |
At the end left wing is out of stand..
Posté le: 10/03/2011 21:18 Sujet du message: |
Right now weight looks good..
