Eric Spore Incurable Posteur
Posté le: 20/03/2011 22:40 Sujet du message: |
| I'm using an other trick. When ironing the solartex/diacov on the rib, I'm using a piece of cloth to press the solartex/diacov on the rib (iron in one hand, piece of cloth in the other). The glue on the underside is cooling down very quickly and the covering sticks perfectly on the wood. |
cw Accro Posteur
Posté le: 21/03/2011 00:43 Sujet du message: |
Ah, great minds think alike...! (I use my handkerchief)
 cw |
cw Accro Posteur
Orionis Incurable Posteur
Posté le: 25/03/2011 07:26 Sujet du message: |
This is worst than NCAP crash-tests!
I wouldn't dare doing this!
 Fabrice |
cw Accro Posteur
Posté le: 26/03/2011 21:16 Sujet du message: |
Slowly, the pile of painted parts gets bigger...
 cw |
Posté le: 26/03/2011 21:57 Sujet du message: |
So wouldn't I !  |
cw Accro Posteur
Posté le: 27/03/2011 22:05 Sujet du message: |
Now all the flying surfaces have been Solartexed...
 cw |
Walter L. Maniaco Posteur
Posté le: 30/03/2011 21:52 Sujet du message: |
Hi Chris,
I really regret that you are not able to show us this extraordinary glider in Normandie. But probably I will have the opportunity to see it on an meeting UK....
Anyway: all the best for you, your family and look forward to a lucky maiden flight.
Best regards
Walter |
cw Accro Posteur
cw Accro Posteur
Posté le: 01/04/2011 21:27 Sujet du message: |
Still painting, still painting...
 cw |
patte de loup Psycho Posteur
Posté le: 02/04/2011 06:31 Sujet du message: |
No far from the end of the building
Too much speed as usual.... maybe only 6 monts for this big isn't it
pat'
Posté le: 03/04/2011 22:27 Sujet du message: |
Hi Chris,
nice painting. Did you paint it 2K? And how did you prime the surface?
I'm just finishing my T21b, it's based on your plan, but a little bit smaller.
The fuselage now is covered with silk and I'm a but undecided how to go on. Can I put the filler directly onto the silk? I'm not sure...
I'm asking you this, because your fuselage is smoothed and you're probably doing the same job as me.
As walter said, it's a pity you won't participate at Vauville.
Regards,
Frank |
cw Accro Posteur
Posté le: 03/04/2011 23:30 Sujet du message: |
Frank, all the material I use to paint models with is 2K. For a translucent finish, first I spray 2 coats of 2K lacquer. This is then wet-flatted with 600 paper and one more coat of semi-gloss lacquer applied. The fabric is now filled and sealed and can be masked out for the trim colors without the paint 'creeping' under the tape. I use 3mm 3M Fine Line tape for the masking.
On the fuselage I use 2K Hi-Build primer over the Solartex joins, which is then flatted until the joins have been smoothed out. Then two coats of color, which is similarly flatted before the final color and trim colors are applied...
It is a lot work ![[argh]](images/smiles/argh.gif)
 cw |
Posté le: 04/04/2011 06:24 Sujet du message: |
Hi Chris,
thanks for the quick answer!
Putting on so many coats really takes a lot of time.
On the T21b. I don't want a perfect surface, it has do look somehow used and DIY.
Frank |
cw Accro Posteur
Posté le: 13/04/2011 21:11 Sujet du message: |
Coming close to the end now...premiere vol maybe over Easter
 cw |
Posté le: 13/04/2011 21:17 Sujet du message: |
Close to the end I cross fingers for the maiden flight, that will be successful as usual Will fly like bells on Easter  |
cw Accro Posteur
Posté le: 16/04/2011 14:35 Sujet du message: |
Le chien 'Henri'
 cw |
Posté le: 16/04/2011 17:22 Sujet du message: |
" Henri the Glider Keeper"
maiden flight completed or not? Tomorrow?  |
cw Accro Posteur
Posté le: 16/04/2011 18:51 Sujet du message: |
Not quite there yet, the radio to fit and a few mistakes to correct, like this one
 cw |
Posté le: 16/04/2011 19:27 Sujet du message: |
too much beautifull
congratulations
Pat"
Posté le: 16/04/2011 21:52 Sujet du message: |
Yes, for it's more an airbrake than a strut !  |
cw Accro Posteur
Posté le: 26/04/2011 22:10 Sujet du message: |
The decals arrived today, so this evening I was able to take the first photos.
I couldn't help myself...the wind was not on the slope, but I gave her a little hand launch over the flat, just to make sure she flies.
Duration of first flight: 2.5 seconds
 cw |
haju68 Fidèle Posteur
Posté le: 26/04/2011 22:33 Sujet du message: |
Congratulation for this first short flight. I am sure it will be longer next time
Very nice glider!
 Julien
Posé pas cassé! Ouf!
Mes dessins aéros : www.haju68.comoj.com |
Posté le: 27/04/2011 07:45 Sujet du message: |
Ouahhhhhh...... wonderfull.
Another beautifull plane in your collection...
Congratulations
Stefan Hunziker Fidèle Posteur
Posté le: 27/04/2011 08:50 Sujet du message: |
Great glider!!
I am looking forward to see the go pro videos you are going to film with it posted on your youtube channel....
i wish i could build as fast as you!!! i started my little Mösch around the same time as you started the Spalinger and although mine is much less work - its not finished yet.....
cheers
Stefan |
Posté le: 27/04/2011 09:22 Sujet du message: |
What a lovely sailplane ( Ah, ces ailes en mouette !!! )
great Chris! ; 2,5 seconds : the shortest time in gliding history?
What a pity you are not with us in Vauville !  |
Posté le: 27/04/2011 09:56 Sujet du message: |
Grandemago Stagiaire Posteur
Posté le: 27/04/2011 11:20 Sujet du message: |
![[bave]](images/smiles/bave.gif) |
cw Accro Posteur
Posté le: 27/04/2011 20:08 Sujet du message: |
Aaah, I am getting old...ten years ago that would have been a 3.5 second flight
 cw |
