SPALINGER S25 1:3.5
Âge: 65 Bélier
MessagePosté le: 20/03/2011 22:40    Sujet du message: Répondre en citant
I'm using an other trick. When ironing the solartex/diacov on the rib, I'm using a piece of cloth to press the solartex/diacov on the rib (iron in one hand, piece of cloth in the other). The glue on the underside is cooling down very quickly and the covering sticks perfectly on the wood.
cw
Âge: 77 Sagittaire
MessagePosté le: 21/03/2011 00:43    Sujet du message: Répondre en citant
Ah, great minds think alike...! (I use my handkerchief) Very Happy
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 24/03/2011 20:50    Sujet du message: Répondre en citant
I do not like rigidly fixing wings to the fuselage because in a heavy landing something is going to break. here is a short video showing a test of my rubber band wing retaining system which aproximates a typical CW landing... Laughing
http://s17.photobucket.com/albums/b59/chriswilliams4/?action=view&current=Untitled.mp4
cw
Âge: 59 Bélier
MessagePosté le: 25/03/2011 07:26    Sujet du message: Répondre en citant
This is worst than NCAP crash-tests! [confus]
I wouldn't dare doing this!
cw
Âge: 77 Sagittaire
MessagePosté le: 26/03/2011 21:16    Sujet du message: Répondre en citant
Slowly, the pile of painted parts gets bigger... Wink
cw
MessagePosté le: 26/03/2011 21:57    Sujet du message: Répondre en citant
So wouldn't I ! Embarassed Laughing
cw
Âge: 77 Sagittaire
MessagePosté le: 27/03/2011 22:05    Sujet du message: Répondre en citant
Now all the flying surfaces have been Solartexed...
cw
Walter L.
MessagePosté le: 30/03/2011 21:52    Sujet du message: Répondre en citant
Hi Chris,
I really regret that you are not able to show us this extraordinary glider in Normandie. But probably I will have the opportunity to see it on an meeting UK....
Anyway: all the best for you, your family and look forward to a lucky maiden flight.
Best regards
cw
Âge: 77 Sagittaire
MessagePosté le: 30/03/2011 23:18    Sujet du message: Répondre en citant
Thank you Walter...you can always see the UK events here:
http://www.scalesoaring.co.uk/Calendar/Calendar.html
cw
cw
Âge: 77 Sagittaire
MessagePosté le: 01/04/2011 21:27    Sujet du message: Répondre en citant
Still painting, still painting... Zzz
cw
MessagePosté le: 02/04/2011 06:31    Sujet du message: Répondre en citant
No far from the end of the building Wink
Too much speed as usual.... maybe only 6 monts for this big [humm] isn't it
[clap] [clap]
pat'
Frank Albrecht
Âge: 60 Vierge
MessagePosté le: 03/04/2011 22:27    Sujet du message: Répondre en citant
Hi Chris,
nice painting. Did you paint it 2K? And how did you prime the surface?
I'm just finishing my T21b, it's based on your plan, but a little bit smaller.
The fuselage now is covered with silk and I'm a but undecided how to go on. Can I put the filler directly onto the silk? I'm not sure...
I'm asking you this, because your fuselage is smoothed and you're probably doing the same job as me.
As walter said, it's a pity you won't participate at Vauville.
Regards,
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 03/04/2011 23:30    Sujet du message: Répondre en citant
Frank, all the material I use to paint models with is 2K. For a translucent finish, first I spray 2 coats of 2K lacquer. This is then wet-flatted with 600 paper and one more coat of semi-gloss lacquer applied. The fabric is now filled and sealed and can be masked out for the trim colors without the paint 'creeping' under the tape. I use 3mm 3M Fine Line tape for the masking.
On the fuselage I use 2K Hi-Build primer over the Solartex joins, which is then flatted until the joins have been smoothed out. Then two coats of color, which is similarly flatted before the final color and trim colors are applied...
It is a lot work [argh]
cw
Frank Albrecht
Âge: 60 Vierge
Nouveau messagePosté le: 04/04/2011 06:24    Sujet du message: Répondre en citant
Hi Chris,
thanks for the quick answer!
Putting on so many coats really takes a lot of time. Wink
On the T21b. I don't want a perfect surface, it has do look somehow used and DIY.
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 13/04/2011 21:11    Sujet du message: Répondre en citant
Coming close to the end now...premiere vol maybe over Easter
cw
Nouveau messagePosté le: 13/04/2011 21:17    Sujet du message: Répondre en citant
Close to the end Very Happy I cross fingers for the maiden flight, that will be successful as usual Wink Will fly like bells on Easter Laughing
Nouveau messagePosté le: 14/04/2011 11:32    Sujet du message: Répondre en citant
Not really, The rubber is still missing ( the red line along the fuselage ) Wink
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 16/04/2011 14:35    Sujet du message: Répondre en citant
Le chien 'Henri'
cw
Nouveau messagePosté le: 16/04/2011 17:22    Sujet du message: Répondre en citant
" Henri the Glider Keeper" Laughing
maiden flight completed or not? Tomorrow? Wink
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 16/04/2011 18:51    Sujet du message: Répondre en citant
Not quite there yet, the radio to fit and a few mistakes to correct, like this one MDR
cw
Nouveau messagePosté le: 16/04/2011 19:27    Sujet du message: Répondre en citant
too much beautifull [clap] [clap] [clap]
congratulations [amen]
Pat"
Nouveau messagePosté le: 16/04/2011 21:52    Sujet du message: Répondre en citant
Yes, for it's more an airbrake than a strut ! Laughing
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 26/04/2011 22:10    Sujet du message: Répondre en citant
The decals arrived today, so this evening I was able to take the first photos.
I couldn't help myself...the wind was not on the slope, but I gave her a little hand launch over the flat, just to make sure she flies.
Duration of first flight: 2.5 seconds Very Happy
cw
haju68
Âge: 40 Vierge
Nouveau messagePosté le: 26/04/2011 22:33    Sujet du message: Répondre en citant
Congratulation for this first short flight. I am sure it will be longer next time Wink
Very nice glider!
Julien
Posé pas cassé! Ouf!
Nouveau messagePosté le: 27/04/2011 07:45    Sujet du message: Répondre en citant
Ouahhhhhh...... wonderfull. [clap] [clap] [clap]
Another beautifull plane in your collection... Wink
Congratulations
Stefan Hunziker
Âge: 55 Balance
Nouveau messagePosté le: 27/04/2011 08:50    Sujet du message: Répondre en citant
Great glider!!
I am looking forward to see the go pro videos you are going to film with it posted on your youtube channel....
i wish i could build as fast as you!!! i started my little Mösch around the same time as you started the Spalinger and although mine is much less work - its not finished yet.....
cheers
Stefan
Nouveau messagePosté le: 27/04/2011 09:22    Sujet du message: Répondre en citant
What a lovely sailplane ( Ah, ces ailes en mouette !!! )
great Chris! ; 2,5 seconds : the shortest time in gliding history? Laughing
What a pity you are not with us in Vauville ! Confused
Nouveau messagePosté le: 27/04/2011 09:56    Sujet du message: Répondre en citant
Grandemago
Âge: 53 Capricorne
Nouveau messagePosté le: 27/04/2011 11:20    Sujet du message: Répondre en citant
[clap] [clap] [clap] [bave]
cw
Âge: 77 Sagittaire
Nouveau messagePosté le: 27/04/2011 20:08    Sujet du message: Répondre en citant
Aaah, I am getting old...ten years ago that would have been a 3.5 second flight Very Happy
cw
Page 3 sur 4
