Minimoa 1:2.5
Rusjan
Âge: 56 Lion
MessagePosté le: 24/05/2010 17:39    Sujet du message: Minimoa 1:2.5 Répondre en citant
Here we go again Very Happy Very Happy Very Happy ... This time even bigger and for sure more scale Wink ...
Current condition...
looking rather small at 2.8m fuselage Very Happy ...
Regards !
Uroš
Rusjan
Âge: 56 Lion
MessagePosté le: 11/06/2010 01:42    Sujet du message: Mninmoa ! Répondre en citant
Some work was done on the elevator Very Happy ...
from the side...
1200mm [houla] ...
Regards !
Uroš
MessagePosté le: 11/06/2010 05:25    Sujet du message: Répondre en citant
Hi Uroš,
Very clean [good] what will be your choice for the color scheme? the same HB282 or another?
MessagePosté le: 11/06/2010 06:52    Sujet du message: Répondre en citant
Nice work, the Minimoa is always welcome Very Happy such a mythic glider [clap]
personal drawings or enlarged plans ? A scale masterpiece this time !! Wink
Rusjan
Âge: 56 Lion
MessagePosté le: 11/06/2010 08:33    Sujet du message: Minimoa ! Répondre en citant
Hi Uroš,
As a tribute to 1:3.5 (RIP) it will be hb-282 design, but this time covered with oratex and painted...
Regards !
Uroš
MessagePosté le: 11/06/2010 09:41    Sujet du message: Répondre en citant
and with the right canopy you'll have to mould ???? Wink I have some nice pictures of the internal settlement and many others if you need... I made one HB 282 at 1:4 scale Very Happy
cw
Âge: 78 Sagittaire
MessagePosté le: 11/06/2010 18:51    Sujet du message: Répondre en citant
RIP, Uroš...?
cw
Rusjan
Âge: 56 Lion
MessagePosté le: 11/06/2010 19:37    Sujet du message: Répondre en citant
« cw » a écrit:
RIP, Uroš...?
Quite seriously damaged, especially front section of the fuse. For the moment it is "resting" on the shelf, but as they say, time is a healer Very Happy ...so will try to bring her back Very Happy ...
Regards !
Uroš
Rusjan
Âge: 56 Lion
MessagePosté le: 18/06/2010 14:32    Sujet du message: Minimoa ! Répondre en citant
Some more work done on the rudder Very Happy Very Happy ....
on the fuselage...
wondering if this all together is to BIG [humm] [humm] ....
just the right size Wink Wink Wink ...
Regards !
Uroš
Peter64
Âge: 61 Gémeau
Nouveau messagePosté le: 18/06/2010 20:53    Sujet du message: Répondre en citant
Hallo Uros,
nice rudder, good work [clap] [clap] .
Greetings
Peter
Nouveau messagePosté le: 19/06/2010 14:26    Sujet du message: Répondre en citant
Congratulations Very Happy
Olivier
Âge: 39 Sagittaire
Nouveau messagePosté le: 19/06/2010 16:21    Sujet du message: Répondre en citant
Huuuuuuuuuuuuuuuge !! [amen]
What is the weight ?
La Vie c'est un truc de DIINGUES !! 31
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 19/06/2010 20:56    Sujet du message: Répondre en citant
Didn't put it on the scale yet Embarassed ... will do that later on Cool ...
Regards !
Uroš
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 19/07/2010 19:04    Sujet du message: Minimoa ! Répondre en citant
Some more progress on inner wing section Very Happy Very Happy ....
Ribs...
Template...
It's easy with fixed ribs...
And the result Very Happy Very Happy ...
2.6m Very Happy Very Happy Very Happy ...
Still missing 2 meters on each side [humm] [humm] ...
Regards !
Uroš
Nouveau messagePosté le: 19/07/2010 21:27    Sujet du message: Répondre en citant
Nice work but why so many spars on the inner wing? [humm] (according to the scale appearance?) [humm]
Âge: 76 Poissons
Nouveau messagePosté le: 20/07/2010 02:17    Sujet du message: Répondre en citant
Normal that you make as great , with as beautiful vegetables in the garden Wink
good work
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 20/07/2010 07:56    Sujet du message: Répondre en citant
You are right, that's not entirely scale design Embarassed . But with wing root at 52cm I was a bit worried about mechanical aspect. As the front side will be planked only the two spars will be visible. Still one too much Embarassed , but I just wanted to be on the safe side Rolling Eyes ...
good work
That's one of my wife's contributions to this project Very Happy ...
Nouveau messagePosté le: 20/07/2010 08:20    Sujet du message: Répondre en citant
I understand your fear , I suppose you put a cap on the ribs so the spar will not appear directly after the wing is covered Very Happy nevertheless there is no problem if you build a strong trailing edge.Do you install airbrakes on upper and bottom sides of the wing?
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 20/07/2010 13:47    Sujet du message: Minimoa ! Répondre en citant
Not sure about the airbrakes yet Embarassed ... It would be much easier to make them just on the upper side. On the other side, two sided airbrakes, like the one I made on my Kranich, add that something to real front figure when you are aproaching for landing Very Happy Very Happy ...
Nouveau messagePosté le: 20/07/2010 16:20    Sujet du message: Répondre en citant
If you're not involved in a true scale sailplane, make the simpliest way... Very Happy
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 20/07/2010 20:37    Sujet du message: Répondre en citant
Probably will Embarassed , like in cw plan.
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 02/11/2010 11:19    Sujet du message: Minimoa ! Répondre en citant
Quite some progress was made in past few weeks Very Happy ... This is the current state of the project...
Regards !
Uroš
Nouveau messagePosté le: 02/11/2010 12:02    Sujet du message: Répondre en citant
Hallo Uroš,
Sieht einfach toll aus, deine MiMo [amen]
Schade das das Holzwerk wieder verdeckt wird Wink
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 02/11/2010 12:34    Sujet du message: Répondre en citant
« Johannes » a écrit:
Hallo Uroš,
Dieses mal nicht [non] ... Wird mit oratex natur gespannt Very Happy ...
Uroš
Nouveau messagePosté le: 02/11/2010 13:35    Sujet du message: Répondre en citant
Hi, Uros, nice building!
It's a good thing you've built its own shelter! Very Happy
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 02/11/2010 14:25    Sujet du message: Minimoa ! Répondre en citant
Never thought that jutting roof that I built a few years ago for my car, will someday serve as a hangar for my Bigmoa Very Happy ...
Regards !
Uroš
Walter L.
Nouveau messagePosté le: 02/11/2010 21:51    Sujet du message: Répondre en citant
Hello Uroš,
your glider is really great!
Which profile do you use?
Do you have an idea which weight the modell will have?
Best regards
Nouveau messagePosté le: 02/11/2010 22:42    Sujet du message: Répondre en citant
Great job, no doubt I will also build a big Minimoa one day after the one I made a few years ago at 1:3,5 scale, even if it's a great classic often built...Maybe the two seater... Which scheme did you choose for yours?
[clap] [clap]
Rusjan
Âge: 56 Lion
Nouveau messagePosté le: 03/11/2010 08:53    Sujet du message: Répondre en citant
« Walter L. » a écrit:
Hello Uroš,
Best regards
I used HQ 3.5/14 on the middle section and HQ 3.5/12 on the outside. Regarding weight, it sould be under 20kg, I guess around 17kg.
[clap] [clap]
It will be HB-232 design. Covered with natur oratex and painted white.
Regards !
Uroš
Nouveau messagePosté le: 03/11/2010 12:17    Sujet du message: Répondre en citant
Good job Uros [clap]
I use the same profile on my new C 25, normaly it's efficient and not too speed Wink
Page 1 sur 3
