Rusjan Apprenti Posteur
 Posté le: 24/05/2010 17:39    Sujet du message: Minimoa 1:2.5 |
Here we go again         ... This time even bigger and for sure more scale   ...
Current  condition...
looking rather small at 2.8m fuselage   ...
Regards !
Uroš |
 Posté le: 11/06/2010 01:42    Sujet du message: Mninmoa ! |
Some work was done on the elevator   ...
from the side...
1200mm    ...
Regards !
Uroš |
 Posté le: 11/06/2010 05:25    Sujet du message:  |
Hi Uroš,
Very clean   what will be your choice for the color scheme? the same HB282 or another? |
 Posté le: 11/06/2010 06:52    Sujet du message:  |
Nice work, the Minimoa is  always  welcome     such a mythic glider
personal drawings or  enlarged plans ? A scale masterpiece this time !!   |
 Posté le: 11/06/2010 08:33    Sujet du message: Minimoa ! |
	« VincentB » a écrit: 	Hi Uroš,
Very clean  ![[good]](images/smiles/good.gif)  what will be your choice for the color scheme? the same HB282 or another?
As a tribute to 1:3.5 (RIP) it will be hb-282 design, but this time covered with oratex and painted...
Regards !
Uroš |
 Posté le: 11/06/2010 09:41    Sujet du message:  |
and with the right canopy you'll have to mould ????    I have some nice pictures  of the internal settlement and many others if you need...  I made one HB 282 at 1:4 scale    |
cw Accro Posteur
 Posté le: 11/06/2010 18:51    Sujet du message:  |
RIP, Uroš...?
   cw |
 Posté le: 18/06/2010 14:32    Sujet du message: Minimoa ! |
Some more work done on the rudder      ....
on the fuselage...
wondering if this all together is to BIG      ....
just the right size          ...
Regards !
Uroš |
Peter64 Maniaco Posteur
 Posté le: 18/06/2010 20:53    Sujet du message:  |
Hallo Uros,
nice rudder, good work      .
Greetings
Peter |
 Posté le: 19/06/2010 14:26    Sujet du message:  |
Congratulations    |
Olivier Fidèle Posteur
 Posté le: 19/06/2010 16:21    Sujet du message:  |
Huuuuuuuuuuuuuuuge !!
What is the weight ?
   La Vie c'est un truc de DIINGUES !!    |
 Posté le: 19/07/2010 19:04    Sujet du message: Minimoa ! |
Some more progress on inner wing section      ....
Ribs...
Template...
It's easy with fixed ribs...
And the result      ...
2.6m          ...
Still missing 2 meters on each side      ...
Regards !
Uroš |
 Posté le: 19/07/2010 21:27    Sujet du message:  |
Nice work but why so many spars on the inner wing?   (according to the scale appearance?)  ![[humm]](images/smiles/humm.gif)  |
DELRIEUPierre Psycho Posteur
 Posté le: 20/07/2010 02:17    Sujet du message:  |
Normal that you make as great  , with as beautiful vegetables in the garden
good work
Pierre |
 Posté le: 20/07/2010 07:56    Sujet du message:  |
	« Hecquetmarc » a écrit: 	Nice work but why so many spars on the inner wing?  ![[humm]](images/smiles/humm.gif)  (according to the scale appearance?)
You are right, that's not entirely scale design   . But with wing root at 52cm I was a bit worried about mechanical aspect. As the front side will be planked only the two spars will be visible. Still one too much   , but I just wanted to be on the safe side    ...
	« DELRIEUPierre » a écrit: 	Normal that you make as great  , with as beautiful vegetables in the garden
good work
That's one of my wife's contributions to this project   ... |
 Posté le: 20/07/2010 08:20    Sujet du message:  |
I understand your fear , I  suppose you put a cap on the ribs so the spar will not appear directly after the wing is covered     nevertheless there is no problem if  you build a strong trailing edge.Do you install airbrakes on upper and bottom sides of the wing? |
 Posté le: 20/07/2010 13:47    Sujet du message: Minimoa ! |
Not sure about the airbrakes yet   ... It would be much easier to make them just on the upper side. On the other side, two sided airbrakes, like the one I made on my Kranich, add that something to real front figure when you are aproaching for landing      ... |
 Posté le: 20/07/2010 16:20    Sujet du message:  |
If you're not involved in a true  scale  sailplane, make the  simpliest way...   |
 Posté le: 02/11/2010 11:19    Sujet du message: Minimoa ! |
Quite some progress was made in past few weeks   ... This is the current state of the project...
Regards !
Uroš |
 Posté le: 02/11/2010 12:02    Sujet du message:  |
Hallo Uroš,
Sieht einfach toll aus, deine MiMo
Schade das das Holzwerk wieder verdeckt wird
Gruß Johannes |
 Posté le: 02/11/2010 12:34    Sujet du message:  |
	« Johannes » a écrit: 	Hallo Uroš,
Dieses mal nicht   ... Wird mit oratex natur gespannt   ...
Uroš |
Orionis Incurable Posteur
 Posté le: 02/11/2010 13:35    Sujet du message:  |
Hi, Uros, nice building!
It's a good thing you've built its own shelter!
   Fabrice |
Walter L. Maniaco Posteur
 Posté le: 02/11/2010 21:51    Sujet du message:  |
Hello Uroš,
your glider is really great!
Which profile do you use?
Do you have an idea which weight the modell will have?
Best regards
Walter |
 Posté le: 02/11/2010 22:42    Sujet du message:  |
Great job, no doubt I will also build  a big Minimoa one day  after the one I made a few years ago  at 1:3,5 scale, even if it's a great  classic often  built...Maybe the two seater... Which scheme did you choose  for  yours?
    ![[clap]](images/smiles/Clap.gif)  |
 Posté le: 03/11/2010 08:53    Sujet du message:  |
	« Walter L. » a écrit: 	Hello Uroš,
Best regards
I used HQ 3.5/14 on the middle section and HQ 3.5/12 on the outside. Regarding weight, it sould be under 20kg, I guess around 17kg.
	« Hecquetmarc » a écrit: 	Great job, no doubt I will also build  a big Minimoa one day  after the one I made a few years ago  at 1:3,5 scale, even if it's a great  classic often  built...Maybe the two seater... Which scheme did you choose  for  yours?
It will be HB-232 design. Covered with natur oratex and painted white.
Regards !
Uroš |
 Posté le: 03/11/2010 12:17    Sujet du message:  |
Good job Uros
I use the same profile on my new C 25, normaly it's efficient and not too speed
